Do you have to use Holleys projections fuel pump or can I
Discussion in 'The Garage' started by 73K5Kid, Apr 30, 2003.
  1. 73K5Kid
    73K5Kid 1/2 ton status
    Sep 24, 2002
    583
    chandler az
    use an aftermarket one. I did a search and didn't come up with much. Cause I am thinking about buying a used pro-jection and it needs a fuel pump. I don't want to have to spend another 180 bucks on there fuel pump. If I can get one cheaper. I know it has to be an external pump with 15ps.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Holley's electric EFI fuel pumps are legendary for their inability to function for more than a few weeks or months. I'd recommend buying anything BUT a Holley pump. A stock pump from any TBI application will provide the correct pressure.
  3. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I personally would go with a Aeromotive pump and trhow a regulator on it... /forums/images/graemlins/thumb.gif IMHO, I am with Harry...Holly pumps eat the dust a little too early and when they do work the MOFO's are LOUD....
    Chris
  4. dyeager535
    26,975
    Don't the pro-jections themselves have a horrible reputation?
    Not sure of specifics, but I recall hearing things about the pro-jection setups.
    Might want to check around to see how people like theirs that have been running it more than a few months.
  5. BARRAZA
    BARRAZA 1/2 ton status
    Oct 17, 2001
    259
    USA
    I've been using one for eight years with no problems on the original pump, but I have heard stories of pumps not lasting also. I suspect it has to do with sucking trash through it, follow the directions and use a good filter before the pump. If the system needs a new pump, it doesn't matter what pump you use as long as it is capable of the output pressure. IIRC the voltage output to the pump varies with load and the book recommends using a relay so high output engines always receive 12v, if you use a pump other than theirs, you would probably want to do this.
  6. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I've had my Holley pump for over two years now. And you cant hear it run at all.
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Consider yourself lucky! /forums/images/graemlins/wink.gif I know people that have gone through 2 or 3 Holley pumps before switching to a different brand. After that, their Projection systems ran pretty good. /forums/images/graemlins/thumb.gif
  8. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    I am with Sandman on this, I had my projection using the holley pump for two years with out a problem. Drove it almost every day too. I think pump location might be some people's problems.
  9. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Could be, but when I hear the same story from 8 or 10 different people, then I have to wonder about the quality of the pumps. Perhaps Holley wised up and improved their design in the last few years, but they already tainted their reputation with me. /forums/images/graemlins/frown.gif
  10. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    The Holley Pro-Jection has a regulator built into the
    Throttle Body Unit. My first pump lasted about 2 years
    or about 6000 miles, got Holley to replace it, never
    returned it, but when I opened it up to see why it failed
    the electric motor failed the Commutator and rotor windings
    looked like they where sand blasted. And I used a good
    filter before the pump(10-20micon's). Also stamped into
    the outer case was CARTER and numbers.
    Second pump is making some noise now, so I will cross my
    fingers and hope to get some more use out of it. But I
    too am looking for an Aftermarket pump, so far
    I hear the Bosch($$$$$) is the way to go.
