Do you know how many cfm my carbs are?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigerik, Apr 2, 2001.
  1. bigerik
    bigerik 1/2 ton status
    Feb 24, 2001
    184
    Sonoma County, CA
    I thought I knew how many cfms my carbs are, but then I found some conflicting data. The 1976 Jimmy came with a 4 barrel Q-jet on a small block 400/TH350/NP203. It has a divorced choke and 1 3/8" primaries and 2" secondaries. What is cfm? The 1981 Chevy Shortbox started as a 1/2 ton with a 4 barrel Q-jet on a 350/TH400/NP208. It has an electric choke and 1 3/8" primaries and 2" secondaries. What is cfm? I should know this! Trucks are at <A target="_blank" HREF=http://www.bigerik.coloradoK5.com>http://www.bigerik.coloradoK5.com</A>
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Either they will be 750 or 795 cfm. I don't think GM had any other Q-jet's other then those cfm ratings.
    <A target="_blank" HREF=http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html>http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html</A>
    <font color=blue>Happy Trails[​IMG]</font color=blue>
    <font color=blue>Wayne</font color=blue>
  3. bigerik
    Feb 24, 2001
    184
    Sonoma County, CA
    That's what I thought! My mechanic said, though that they were 550 or 600 (I can't remember because I was so shocked). He proceeded to say that "I had the ones with the small primaries, but then I read that "all Q-jets except for the 850 cfm ones had 1 3/8" primaries." The mechanic has owned a 1972 Chevy 1/2 ton for decades and has always been a mechanic (even when he was an infant (JK)). He also said that the stock coil for GM HEI is 60,000 volts which I know is not true because they sell those 40,000+ volt induction coils that say "more voltage than OEM." I think stock is 32,000 volts. It is weird that he would give me bad data, but I have always read that the Jimmy would have a 750 cfm and the Silverado would have a 795 cfm.
  4. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Hey all
    I read a post on this at<A target="_blank" HREF=http://www.chevytalk.com>http://www.chevytalk.com</A>
    I seem to remember reading that the 795 has a ridge or ring part way down the venture(sp).
    I don't claim know everthing on Q-jets, but I have never heard of a 550 or 600 Q-jet.
    Hey Ric Nice rigs
    See ya
    my truck's not dirty, it's earth tone paint
  5. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I also don't think there were any 500-600 cfm Q-jets. According to my Doug Roe's Book on Q-jets, 1-3/32" primary venturi (not bore) are 750cfm carbs, and 1-7/32 venturi are 795 cfm Q-jets.
    Hope this helps.
    <font color=blue>//////
    <A target="_blank" HREF=http://blazer79.coloradok5.com>http://blazer79.coloradok5.com</A>
    </font color=blue>[​IMG]
  6. Grim-Reaper
    7,385
    Atlanta
    All are 750 or better. The design of a quad is that it adjust by vacume the amount of air it will flow. that's what the doors are for above the secondaries. If the engine can only handle 450cfm the the carb becomes a 450 CFM.
    Fact of the matter is most SB Chevy's that are mostly stock only need about 500-550 CFM. Big Block more. By making the carb self adjusting GM used one carb for Big and Small and saved stocking fee's.
    So yes of your motor can pull 650 CFM your quad will become a 650 CFM.
    Diging it in the dirt with my K5's
    Grim-Reaper
    <A target="_blank" HREF=http://grimsk5s.coloradok5.com/>http://grimsk5s.coloradok5.com/</A>
  7. bigerik
    Feb 24, 2001
    184
    Sonoma County, CA
    So just to clarify: you are saying that the carb on the Jimmy appears to be a 750 cfm and the carb on the Silverado appears to be a 795 cfm? I understand that the airflow is subject to vacuum/engine demand. By the way, what is a moderator on your name there, Grim-Reaper?
    It means I can come in and mess with your post [​IMG]
    <P ID="edit"><FONT SIZE=-1>Edited by Grim-Reaper on 04/03/01 10:21 AM (server time).</FONT></P>
  8. Grim-Reaper
    7,385
    Atlanta
    Just an extra set of eye's to help Steve monitor the board. If somebody were to get out of hand I can kill their post if needed and put an end to any problems.
    Grim-Reaper
  9. dyeager535
    26,982
    191
    Check out the Q-jet links on my page link below. There is a very good picture that I edited showing the difference between the two. FWIW, GM used the Q-jet on straight sixes as well....Most are mechanically limited well below what they can actually flow by the tang on the passenger side of the air valve shaft that prevents them from opening fully. Generally, the newer the carb, the more that tab restricts secondary opening. The tang can be easily removed.
    795/800 CFM (no one seems to agree what the number is really) carbs seem to be MUCH more rare on the pre '75 carbs. I have yet to see one as a matter of fact, and I have carbs from SD455's from the early 70's in my "collection" Almost all Oldsmobile carbs from about 77-90 are 800 CFM units, but they do not have the same fuel inlet.
    At least on an '82 K5, 700, AC, 305, the stock carb was an 800CFM unit. Not sure about the 350's and 454's, but I would think GM would have used them across the board at that point, but who knows. Haven't got to look at any but the 305's so far.
    Bigger is not always better, as MPG will be affected negatively, and so can throttle response, by going with a larger CFM Q-jet.
    Dorian
  10. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I know a guy that has an old Jeep that he put a 4.3L V6 in. The engine came from a Chevy truck and has the factory installed Q-Jet sitting on top of it! Blew my mind the first time I saw it! It looks huge sitting on top of that little engine. Apparently that was the stock engine in 3/4-ton trucks for a while. [​IMG]
