do you think it will look gay?
Discussion in 'The Garage' started by SHAWNSTER, Jul 31, 2006.
  1. SHAWNSTER
    SHAWNSTER 1/2 ton status
    Sep 24, 2002
    211
    DALLAS,TX
    will look gay if I prime and paint some brackets and radiator supports and misc brackets in glossy black on my 62 cadi-everything has surface rust on it- i started w/ the power steering and air tank-and last night i did the whole
    radiator and core support area and i think it might be too much black-what do ya'll think????
    thanks
  2. goldwing2000
    goldwing2000 Guest
    It was probably black from the factory. No reason it wouldn't look just fine.
  3. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I think flat black would look good.
  5. Mudgod
    Mudgod Registered Member
    Dec 19, 2004
    92
    Gilmer, TX
    If you have to ask it might be.
    J/K mind are painted.
  6. SHAWNSTER
    Sep 24, 2002
    211
    DALLAS,TX
    my bud said flat black, but i thought glossy would look better-i will pick up a can and check it out-that would be a lot of wire wheelin and sanding to get all the glossy black off
  7. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I perfer semi gloss. the look of gloss black on stuff just looks like you gave it the car lot special..
  8. divorced
    Jul 20, 2004
    5,115
    You may be able to paint over the gloss with the flat. Gloss black seems to show any imperfection under it and is a lot harder to keep clean.
    Here is a pic of my frame and springs on my '96 K1500. I painted the entire frame, suspension, lift, and axle with flat. The only prep work was hose it off with a pressure washer. Then I painted it with red primer and covered that with the flat black. It made everything look new again.
