Do you think JB weld will fix this?
Discussion in 'The Garage' started by BadDog, Sep 5, 2004.
  1. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I finally got up the gumption to work on this thing again. Do you tink there is any hope of fixing this with some JB weld? /forums/images/graemlins/tongue.gif /forums/images/graemlins/doah.gif
  2. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    JB is overkill for a small crack like that. Try using duct tape, it's lighter and easier to use. /forums/images/graemlins/histerical.gif
  3. cybrfire
    Dec 15, 2002
    15,143
    579
    Iowa
    Nope. /forums/images/graemlins/yikes.gif
  4. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    nice oh yeah, jb fix that no prob. wate 5 min and drop it in. /forums/images/graemlins/waytogo.gif
    that a 350? got a two wheel one if ya w /forums/images/graemlins/dunno.gifant
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'd try welding that up if I knew how.
  6. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    I was thinking more of the bubble gum route, cheaper ya know,
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/thumb.gif,
    but for real, no way would i use JB on that, mabye weld it but only if the guy really know his shi$ even than im not shure you can weld on cast alumiumn /forums/images/graemlins/dunno.gif
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    LOL, that was definitely a joke. JB or bubble gum, the result would be exactly the same. And it's beyond welding, there are some critical dimensions in there that the crack crosses. Repair cost with necessary equipment and final machine work would DEFINITELY exceed the value of a dozen of those cases.
    It is (was) a th350 and I have another "well used" th350 K-case going in.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If I had the tools I'd weld the piss out of that and try it anyway, you might be shocked.
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Look closer. That crack runs right through the governor bore which is a very critical fit. In fact, a case can be ruined simply by trash getting in there and causing it to wear a bit. IMO, there is no way to get that back together within the few thousandths tolerance required. The only way I can imagine is to weld it up solid and re-machine it. The rest might be manageable, but not that…
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I didn't realize that before, that's probably impossible to get right no matter how hard you try.
  11. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    You don't need that govenor. Go with a manual valve body and TIG it back together.
    Actually I agree that case is now trash. Cast aluminum is probably one of the harder types of welding that can be done (hardest being titanium) and that is a very stressed area the crack is in.
  12. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    JB Weld can fix cylinder heads, why couldn't it fix a transmission? /forums/images/graemlins/confused.gif
  13. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    yikes! thats carnage! /forums/images/graemlins/yikes.gif
  14. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  15. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,175
    132
    Phoenix AZ
    I think the Hydramatic Division of GMC hates your family tree right about now. The wife's car is under warranty, so that all that is left is the Allison /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif.
    You haven't broken that one yet, but I'd keep the boy away from it if I was you /forums/images/graemlins/whistling.gif.
    I'm off tomorrow so let me know if you need an extra body.
  16. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    And cast aluminum saturated with ATF is gonna be absolute hell. Even if you could manage to get it welded the stress would likely crack it elsewhere. FWIW I have welded cast aluminum quite a few times and it's not easy or fun...
    Rene
  17. i_4x4
    i_4x4 1/2 ton status
    Feb 20, 2000
    359
    Brighton, Colorado. USA
    When you get that back together. I know of a place in Las Cruises, NM. To test the repair. /forums/images/graemlins/whistling.gif/forums/images/graemlins/waytogo.gif
  18. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Rene
    Is welding cast anything easy or fun?
  19. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    I have 2 TH350 4x4 trannys out in the shed for parts(cases are fine,some other stuff missing)plus the one in my plow truck that recently lost reverse that is going to be parted out as soon as I finish swapping the 305 in my 79 C10.If I werent so far away you'd have plenty of spare trannys! /forums/images/graemlins/ignore.gif
    Also have a short tail TH350 out of a 73 chevelle that wouldnt move in foreward gears--is it possible to use a car tranny in a 4x4 by swapping the rear output shaft?? or is the car case weaker than a 4x4 version?. /forums/images/graemlins/dunno.gif
    And no,not even the almighty J-B Weld would fix that carnage--the only way to fix that tranny case would be to melt it down into a puddle and re-cast it! /forums/images/graemlins/yikes.gif
  20. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    Cast iron is easier...but also unfun. /forums/images/graemlins/tongue.gif
    Rene
