Do you think my rear springs sag?
Discussion in 'The Garage' started by mountainexplorer, Jul 12, 2005.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    Another typical load by me.
  2. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    well, some lift blocks would clear that up :D
  3. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    yep thay are dead:wink1:
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Or just way overloaded. What's in there?
  5. OffRoad
    OffRoad 1/2 ton status
    Dec 8, 2002
    852
    New Brunswick, Canada
    don't lie, there's like 3 crew cabs on that trailer isn't there? :D
  6. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    Helper springs...
    I put a set of those coil type overload springs that go between the axle and frame rail bump stop brackets on my 74 K20 so I could heap up a big load of sand on it while I was plowing..they cost about 20 bucks at Autozone--the ones I got were 1500lb capacity,but they said they could order 2000 lb ones too..they worked great,they keep the springs from breaking,and my truck actually rode BETTER with them in it,even empty!--it had 9 leaves in the rear springs,but they rode like dead axles..way too stiff,especially empty.. :doah:
    When I added the coils,it took the weight off the leafs some,and gave it some "bounce" instead of feeling like a solid axle..I removed the rubber bump stops and bolted a Mcpherson strut "hat" off a FWD car to the brackets the rubber bumpers went to,and the coil helpers fit nicely inside the "hat"..kept them from sliding around on the brackets,and made sure they could not slip sideways when empty...I probably should have saved the springs and the "hats",but they were pretty rusty--so they went to the crusher with the rest of the truck..I'd buy another set in a heartbeat though...they really did help a lot!...
  7. mountainexplorer
    Nov 14, 2001
    4,903
    A complete 454, 465/205, 12-bolt, Dana 44, my tools, air compressor, BBC rods and pistons and an oil pan, two tires and rims, and a tailgate.
