Do you think this is ok to use
Discussion in 'The Garage' started by 1979jimmy350, Dec 10, 2006.
  1. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    I just bought a used mile marker conversion kit for a NP 203, After looking at it closer there is two chunks missing from each of the gears, one had a the part still on but came off after i poked at it, heres some pics of it
  2. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
  3. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    any body have an idea on this im trying to figure out if i need to ask for my money back
  4. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    I would run it
  5. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    get your money back. if its broken now it can only get worse. why would you install broken parts in something that isn't the easiest to fix later. figure how long is it going to take to install, then uninstall when it gets real bad, then rebuild your T-case cause little chunks of metal have been flying around in there.
    unless the guy that sold it to you informed you that they were broken or cracked. then it's on you.
    Caveat Emptor.
  6. 1977k5
    May 26, 2003
    9,992
    130
    Is it this part that you are concerned about? I have seen spider gears in a diff with much more damage than that last for a long time.
    That probably happened from poor maintenance and/or water/mud contamination.
    Ultimately, its up to you. What you recieved is not perfect but if that is the only problem I don't consider it a huge deal. My .02
  7. destinbeachman
    destinbeachman 1/2 ton status
    Aug 31, 2005
    365
    Florida
    The corner being knocked off isn't a big deal.It'll work fine in your 203 cause it's working fine in mine and I'm putting some power through it.-Allen
  8. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    thats not what im worried about what you have circled is the MM marking, my worrie is the upper corners all missing
  9. 1977k5
    May 26, 2003
    9,992
    130
    Then don't listen to me :D
