Do you tighten your 8 lug wheel nuts to 118 ft.lbs?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jed, May 16, 2002.
  1. Jed
    Jed Registered Member
    Nov 3, 2001
    60
    Alberta, Canada
    118 ft.lbs is what Haynes says is right for the wheel nuts on 8-lug wheels (9/16 studs). This seems overly tight - what do you guys run them at? My tires are only an embarrasing 31" tall (not for long tho!) so it's not like the mass of 44's has to be restrained.
  2. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    125-140lbs...at work we torque them at 140lbs
  3. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    My god... just tightten the damn things.
    Ken H.
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    My Weld wheels had a sticker on them when I got them new and they require a 125 ft. lbs. spec.
  5. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I've always done 125
  6. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Man, I just tighten them real tight and give it another 1/4 turn. I can't imagine taking out the torque wrench for 32 big a$$ nuts.
    The studs actually stretch when you torque them and if you overtorque them they can stretch till they break. It can happen. If it does, buy a new one and don't tighten them quite as tight next time.
    Don't make it more complicated than it is.
    -- Mike
  7. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    I hear you man! Eveyone is just covering their butts these days.
    Anyone know the correct torque for the gas cap on an 82 K3500 .... passenger side?
    Eric M.
  8. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    I was always told that if you over tighten aluminum wheels they can crack... Is this not true?
  9. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    I thought my chiltons specified 105 for 8 lug & 90 for 6 lug - that's how I torque my 2 k5's (and yes I do torque them), and haven't had a drop of problems to this date.
  10. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    Ken, there is a reason you torq your lug nuts........ It's so you will not warp your brake rotors!
  11. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    jwduke is right.
    However, I think 140 is on the high side!
    You definately should not exceed what the wheel mfg specifies
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I crank them until I can't get them any tighter. Screw torquing anythign that isn't inside a motor.
    If you can figure out how to warp such monstrosities as my rotors, be my guest. You'll break the wheel studs first.
  13. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    I have never used a torque wrenh to put on my wheels. On any of my vehicles. And now I use the impact. I dont go back and cehck them. Man, if I checked the torque on every thing I tightened, I would never get anythign done. I agree some things are important.
    Warp your rotors from tightening the lugs too much. Thats new to me. I could see how it would be possible, but come on.
    Some people are so anal on stuff.
    What is the correct torque for my gas cap?
    Ken H.
  14. jwduke
    Aug 25, 2001
    721
    Tim, I think the torquing of lug nuts is intended for the bozo's at the tire store & their 1,600 ft. lb. torq impact wrenches. I figure if you can tighten it up to where you can remove it again with the tools that Chevy sent you,with your truck, you are ok.
  15. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Technically speaking, yes, you can over tighten your lug nuts. 100-125 is perfectly acceptable. You have to remember that on our trucks, the lug nuts are part of the brake rotor (well, connected to the brake rotor) while on many of the newer cars (most imported) the Studs are not part of the rotors (the rotor slides over the studs).
    I dont understand exactly why this makes a huge difference, but it does. When the studs are part of the brake rotor, over torquing and even torque variances between the bolts arent a huge deal. On the studs arent part of the rotor, over torquing and torque variances cause the rotor to warp.
    I never had a torquing issue until I started driving imported cars! So now, yes, I do use a torque wrench to finish off.
  16. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    man I can tell what I torque practially everything especially in my suspension. call it a waist of time or whatever, but I feel more comfortable that way.
  17. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Ditto. Why NOT do it?
  18. 350S10NJ
    350S10NJ Registered Member
    May 16, 2002
    32
    Southern New Jersey, USA
    Gas cap 12-15 inlb
  19. Ressurection
    Ressurection 1/2 ton status
    May 9, 2000
    360
    Prairie du Sac, Wisconsin
    Jed, pls fill out your profile!! Where do you live? Do your 31"rs have a home? I may be interested. E-mail me at bishopfamilywi@msn.com when u get a chance. Thanks!
