Do you trust your temp gauge?
Discussion in 'The Garage' started by 88-383, Jul 24, 2006.
  1. 88-383
    88-383 1/2 ton status
    Sep 11, 2005
    142
    Tracy. CA
    What does your stock gauge normally read and do you trust it? Mine got up to 210 indicated and I wasn't really liking it. I'm taking the electric off and going with a Flex or maybe a combo of both.
    Kelvin
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Mine runs between 165 and 210 but normally hangs out around 185 not worried about it at all. When my water pump went out it got up to about 240:eek1: but it has tracked fine ever since.
    Ira
  3. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    You have to know that the temp its reading is from inside the head. Its a bit warm, but thats where most vehicles run, just make sure you have a good radiator cap.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I trust mine . I have replaced a sender or two , and used another resistor off a gauge from another cluster to keep my screen printing when my 83 gauge went bad . And I trust it .
    A heavy duty clucth is your friend . 115 outside in AZ , with humidity , and I am idling in front of a friends house last week between the 210 and the mark before it with the a/c on :pimp:
  5. dyeager535
    26,975
    Absolutely trust mine. Checked the ECM temp vs. gauge temp, always very close.
    Even then, you are looking for a variance from the "normal" reading. If it says the engine runs at 220* normally, but actual temp is 195* (for instance) you still watch for climbing temps. If the guage reads something other than normal, you start investigating.
