dodge 1 ton running gear
Discussion in 'General Parts for Sale' started by reeser, Jan 5, 2004.
  1. reeser
    reeser 1/2 ton status
    Oct 8, 2001
    434
    Hayden Lake, ID
    out of a 92 cummins dana 60 and dana 70
    dana 60 almost identical to chevy fronts low miles (75k) complete and in good shape 3.54's
    dana 70 with 1.5" 32 spline axles complete with welded spiders and 3.54's
    asking 1400 obo trades considered.
  2. reeser
    Oct 8, 2001
    434
    Hayden Lake, ID
    best offer!!!!! c'mon!!!
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Are you sure that is a D60 and not a D61? I thought the D60 didnt go higher (numericly lower) than 3.73 gear ratio and that the D61 came out to fill the higher gear ratios.
  4. reeser
    Oct 8, 2001
    434
    Hayden Lake, ID
    i'm sure that it's a dana 60 because it's cast onto the housing. it surely does have 3.54's in it as well.
  5. kennyw
    Jun 9, 2002
    13,223
    94
    3.54 must be the break then... Good luck with selling them /forums/images/graemlins/thumb.gif
  6. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    Whats the difference on a Dana 61?
    I've seen Reesers axles and it looks like every other Dana 60 I've seen. Hmmm... I wonder if 3.54 gears would give my plow truck better mileage on the highway... /forums/images/graemlins/thinking.gif
  7. kennyw
    Jun 9, 2002
    13,223
    94
    The D61 is a slightly modified D60 that they moved the pinion over to allow more room for a higher gear ratios that would not fit in the D60 case. The down side to D61's is they are very limited in gear ratios but all the outer parts are the same as the D60's.
    Why would a plow truck need good mileage on the highway? What size tires, engine, tranny? 3.54 would probably be a decent gear ratio for a stock size tire like 235/85R16 and no overdrive.
  8. reeser
    Oct 8, 2001
    434
    Hayden Lake, ID
    hahahaha
    well you know you ALWAYS have priority with me, however someone is coming out tomorrow night to look at them he says he has 1200 cash, so we'll see!
  9. mountainexplorer
    Nov 14, 2001
    4,903
    Well... my '87 fuel injected 454 plow truck is getting about 5 mpg on the highway (with the plow though). I know it won't get good mileage, but I think some sensor has got to be out of it, cause it's running too rich. It used to have a Dana 60, but I robbed it for another rig. Now with the wear and tear of plowing, I have it set in my mind I'll eventually put a 60 back under it.
    I hope you can sell the axles for cash... so you can re-invest in something and get the right gears and everything you want for the Blazer. But you know if you don't sell them...I'll be bugging you about them. I have 4.10 gears I could swap into that 60 and put it under the plow truck. /forums/images/graemlins/grin.gif
    But I don't think you'd want me to get ahead on the Dana 60 competition we have going. /forums/images/graemlins/wink.gif
