DODGE 1 tons
Discussion in 'The Garage' started by nstarry, Mar 25, 2004.
  1. nstarry
    nstarry 1/2 ton status
    Feb 13, 2004
    349
    st.cloud minnesota
    I had a guy ask me today if I wanted his dodge 1 ton he said "its cab is rotten and he thinks it has that dana drivetrain stuff in it " the motor is shot and hes taking the steel flat bed off he said couple hundred I could have it
    Is this got the D60 and D70 ???
    I have yet to see it so if sombody says it may have the dana s
    I'll go check it out its a little bit of a drive
  2. justinf
    justinf 1/2 ton status
    Sep 23, 2003
    684
    Tuscola, Illinois
    What year is it, and I assume it is four wheel drive? Dodge did use front dana 60s for quite awhile I believe.
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    if it is a true 1ton yes it should have the dana 60 front /forums/images/graemlins/thumb.gif
  4. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Just this spring I bought a 1990 Dodge W-350 SRW for parts. It turned out to have a D60 front.... and a D60 (30 spl) rear. I still find it hard to believe that Dodge would make a 1 ton 4wd truck w/ 30 spline axles in the rear and 35 splines in the front /forums/images/graemlins/rolleyes.gif..... but Dodge has been known to do some weird things...
    Hope this helps...
    Marv
  5. bluejeep
    bluejeep 1/2 ton status
    Jan 9, 2004
    106
    Des Moines, IA
    I still find it hard to believe that Dodge would make a 1 ton 4wd truck w/ 30 spline axles in the rear and 35 splines in the front ..... but Dodge has been known to do some weird things...
    Ford did the exact same thing. Very rare to find a 4x4 F350 in the late '70's with a dana 70 in the back.
  6. nstarry
    Feb 13, 2004
    349
    st.cloud minnesota
    the guy said he thinks late 70s and yes four wheel drive
  7. I have a question about the dodge front dana 60, were they vacuum actuated? I have seen a few of the old dodge army trucks and was thinking about removing one for reseach purposes of course /forums/images/graemlins/thumb.gif and putting it on my Suburban. But i know at some point they went to that vacuum actuated crap. I used to have a 89 4wd 1/2 ton dodge truck with a dana 44 front and it had it.
    Mat
  8. jess
    jess Registered Member
    Jan 4, 2004
    27
    CT
    Dodge had many combos in their srw 1 tons. 72-80 were W300s and 81-93 were W350s. The early 70s srw 1 tons actually used drum braked Dana 70s up front, and believe it or not Dana 60s in the rear, and used divorced np205s. Mid to late 70s 1 tons used 60s front and rear and only came with np203 full time t-cases. So the front D60s had driveflanges instead of lockouts. In the early to mid 80s srw W350s could have either 44 front and 60 rear with np208, or 60s front and back with np205, depending on GVW. I believe 89-93 both W250 HD and W350 had 60s in front and 70s in the rear and np205s. None of the leaf sprung Dodge Dana 60 fronts ever used vacuum. Although they were Dana 60s look out, Dodge typically spec'd thinner tubes and weaker shafts. Hope this helps. /forums/images/graemlins/waytogo.gif
  9. steelsoldiers
    steelsoldiers 1/2 ton status
    Oct 17, 2002
    365
    Charleston, West Virginia
    If you are talking about the M880 1.25-ton Dodge army trucks, they were based on the W200 and had the Dana 44 front end, sorry /forums/images/graemlins/frown.gif
  10. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Like said above, I think 94' and later when they went to a coil suspension is when they started the vaccuum deal. Before that I have always seen lockout hubs on the older dodges.
  11. jess
    Jan 4, 2004
    27
    CT
    As mentioned if it's a late 70s ex-military Dodge then it's most likely a W200 with a full-time 44 front and a 60 rear with np203 t-case. Some Military Dodges had ambulance/communications bodies grafted on behind the cab and a rare few of those were actually 1 tons with Dana 60 fronts.
  12. Yep, talking about the old M880's. I didnt look to see what it had, but now I know. Thanks
  13. steelsoldiers
    Oct 17, 2002
    365
    Man you beat me by like 4 minutes...I guess I type too slow or something /forums/images/graemlins/blush.gif
  14. nstarry
    Feb 13, 2004
    349
    st.cloud minnesota
    hey I check it out last night its the w350 its got a 44 front and 60 rear if anybody wants it i can get the hole truck for 200.00
    208 t-case to its in sothern minnesota
