dodge 205 question
Discussion in 'The Garage' started by big83chevy4x4, Feb 23, 2007.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    doesn't seem to be much info on these as the gm and ford 205s.
    what pattern does it have? did they ever have a rear slip yoke? what front output spline?
    i found one fairly cheap about 1.5 hours away and don't want to drive there for nothing.
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Can't answer your questions but i do know that Dodge ran both a married and a divorced 205.
  3. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    Round pattern--same as Gm 208/241
    No rear slip yoke; fixed yoke only
    32 spline front output
    Fairly scarce, and worth getting if price is under $200.
    Jimbo
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    They are not round pattern. They use the 8-bolt pattern. 23 spline mostly - 29 behind a Cummins. Not sure the spline on a divorced.
  5. Jimbo*
    Mar 8, 2005
    1,420
    roswell, new mexico
    I stand corrected--I understood the later ones to be round.
    Jimbo
  6. u2slow
    May 9, 2001
    2,217
    BC Canada
    They have an adapter that takes it from 8-bolt to round. ;)
  7. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    this is a married setup of a tf727 i think. unsure of year, but i may just have to go look at it. i also know of a divorced ford 203 :thinking: :thinking: :1zhelp: :whistle:
  8. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    The dodge married 205's use a spline sleeve like the majority of the SM465/205 combo's out there. However, theirs didn't suck like GM's did. I know that the 29 spline version (which I think came behind just the getrag 5 speed in the early 90's 3/4 and 1 tons w/ cummins) can fetch a pretty penny for the entire setup.
  9. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    The divorced Dodge 205's had 32 splines for all 3 yokes.
  10. 70GMC
    70GMC Registered Member
    Nov 1, 2006
    40
    Reno, NV
    keep in mind that dodge 205s are drivers side drop so they dont work with GM front axles
  11. u2slow
    May 9, 2001
    2,217
    BC Canada
    There are no Dodge driver-drop 205s. They are all passenger drop.
  12. 70GMC
    Nov 1, 2006
    40
    Reno, NV
    damn i guess its only ford. next time i pick up that crack rock, im only gonna smoke half of it.
