Dodge 205?
Discussion in 'The Garage' started by dyeager535, Nov 2, 2006.
  1. dyeager535
    26,977
    Hope no one was intending to bid on this before I posted, sincere apologies if so...
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&sspagename=ADME%3AB%3AAAQ%3AUS%3A1&viewitem=&item=190046003549
    Anyways, I don't have enough time reading every thread that has search results containing dodge and 205. ANYONE have any idea if that 1991 Dodge 205 uses the same VSS/output shaft/reluctor ring that a GM one does? I'd suspect yes, and it's too far away to bid on just to find out it's not, but I'm curious as it MIGHT provide parts for the ultra rare VSS 205 setups that GM doesn't carry parts for.
    The seller says it does use a VSS on the output shaft, but it's certainly not in the same location as GM's, although the location is unimportant since it's just wiring. I'll ask for a picture of the connector itself.
    My experience trying to track down later Dodge 205 info was quite uninformative, especially when looking for part numbers for the above mentioned pieces.
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Only part that you can't get is the tailhousing itself. The ring cost about $33, and go to the junkyard to the VSS sensor, new they are $100. Drill and tap the housing, and enjoy!!!! I don't think that the Dodge stuff will work or it would have been heard about a long time ago.
  3. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    i wouldnt give him 2 cents.
    he is one of 2 big east coast 60 axle ebay selling monstors. :angry1:
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The VSS on the Dodge 205 is a converter. Mechanical drive input, electric output. I do not know if it produces a signal compatible with Chevy ECMs.
    EDIT: Here's a pic:
  5. dyeager535
    26,977
    Do you have the part numbers by any chance? I don't have parts manual myself, was told those parts were discontinued...
    The Dodge VSS connector *looks* like the GM one, but pointless if it still uses speedo gears even if the signal IS right. Thanks for the pics. :)
