Dodge 3/4 ton
Discussion in 'The Garage' started by 74BBPowerHouse, Jul 12, 2006.
  1. 74BBPowerHouse
    74BBPowerHouse Registered Member
    Mar 17, 2006
    90
    Mount Angel, OR
    will a set of 3/4 ton axels from a 85 dodge turbo diesel 4x4 fit under a chevy? Would there be any mods that are nessasary? thanks
  2. 74BBPowerHouse
    Mar 17, 2006
    90
    Mount Angel, OR
  3. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    I've got some Dodge axle experience..... and some advice.
    Check everything...!
    The answer is - Probably
    Is it something you want - Maybe
    W/ a diesel, you may have a D60 front. Or maybe it's a D44. Either way the axle will bolt into a Chevy, but the spring perch width is like 1/2" different. So you either gotta "pry" the springs into place or use offset bushings to make it right.
    But beware...! There are quirks w/ Dodge axles that are not really documented. I recently found that I had 2 Dodge disc brake D44's that are different widths.... :eek:...
    And if you think it is a D60, beware of the D61....
    Hope I've helped...
    Marv
