dodge d-60 under chevy?
Discussion in 'The Garage' started by SICNICK, Oct 14, 2006.
  1. SICNICK
    SICNICK Registered Member
    Jan 13, 2006
    59
    Fort Collins, CO
    I found a sweet deal on a 1976 dodge w300, will this d-60 go under my 82 3/4 ton chevy that currently has a 10 bolt:eek1: ? Thanks!!:bow:
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    The spring perches are a different width. Some people just force their springs to work with the different width. The right way to do it is to move the perches (though on Chevy 60's the passenger perch is essentially immovable).
  3. SICNICK
    Jan 13, 2006
    59
    Fort Collins, CO
    qwell i found some info...on pirate of all places:wink1: ...and it says the DRW dodge D60 is 6 inches wider than the chevy... That aint gonna work:doah:
  4. 1977k5
    May 26, 2003
    9,996
    134
    It says it is 6" wider because its a dually front end. That has nothing to do with the spring perch width.
  5. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    The difference is a 1/4" per side, inless you have stock springs. Shock mounts are a wee difference, steering I think is too. I put one in my 89 so I could move it around, but didn't hook anything up other than the steering which was crossover. If you can get it for a good price, then get it and make it work.
  6. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    It's really no big deal, I've got one going under one of my burbs'. I simply cut the driver side spring perch off, and moved it out 1/2 inch. This puts the perches inline with the factory springs and mounts. Then I added a 1/2 inch wheel spacer to the driver's side, and everything matches up evenly now.
    Yes, shock mounts are different, but no real obstacle.
    My truck is getting crossover steering.
    Hope this helps.
    Jimbo
  7. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    What about the passenger side tube thats a couple inches shorter than a chevy?
  8. FOR MUD
    FOR MUD 1/2 ton status Premium Member GMOTM Winner
    Apr 6, 2006
    2,812
    396
    Clayton Del
    The brake calipers are different too.The brake line drops in the center and runs out to both sides where short [3"-4"] hoses hook to the calipers . Also the mounting plates have a different bolt pattern than Chevys
  9. SICNICK
    Jan 13, 2006
    59
    Fort Collins, CO
    I understand that, but isnt it gonna look silly with the front of the truck 3" wider on each side???:eek1:
  10. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Uh you convert it to SRW and then it is the same size and has Chevy outers:rolleyes:. A GM DRW 60 is about 10" wider than a SRW
    Ira
  11. SICNICK
    Jan 13, 2006
    59
    Fort Collins, CO
    so then I would need Chevy srw dana 60 outers?
  12. sandawgk5
    Oct 28, 2003
    6,881
    You can turn down your DRW hubs to make SRW hubs or you can buy new hubs for SRW and they will swap out. Dodge and GM use the same length outershaft and spindle.
    http://www.pirate4x4.com/tech/billavista/60_front/index.html
    This article will tell you anything you need to know on converting from DRW to SRW.
    Ira
  13. primerk5
    primerk5 1/2 ton status
    Jan 13, 2001
    220
    Finksburg MD
    [​IMG]Ive got one under my 79 truck. It used to be under my Blazer Which I'll probably post some pics showing it. I have a 14 bolt ff in the rear . Just used a pry bar from the frame to my spring to pull it to the dodge perch. Each pearch is 1/2 inch to the center of the truck. This rear non dually is actually narrower than the Chevys. Which if in your state you have to run flares for over extended tires will be quite conveinent because it sets the tires perfectly inline with the rear tires if not narrower.
    [img[​IMG]
    Sorry I don't have any good pics of the springs being pulled toward the inside of the frame.
    But I forgot to also mention. If you take the Stock Dodge steering arm off the rear and have the hole it machined bigger to the GM draglink/tierodend size (the bolt in peice) you can use it and for a 4 to six in lift you won't have to buy a raised sterring arm for the axle to run the stock drag link. The dodge is raised unlike the normal GM which drops closer to the axle You'll also have to use the Dodge ubolt plates Atleast for the passenger side due to the Dodge 60 has narrower studs than a chevrolet 60. I used Dodge calipers. It seems as if the Chevrolet calipers are the same any how. I just bolted my brakelines up. Dodge uses one single rubber hose down to the axle and it splits on the rear to each side. Just like a chevrolet back rear. Hope this helps.
  14. chevyguybc
    chevyguybc 1/2 ton status
    Nov 12, 2003
    524
    Vancouver Canada
    cant you just drill out the holes on your perchs 1/4 inch then weld it back up and smooth it out, this is what i would do
