Dodge D60/44
Discussion in 'The Garage' started by bangedup, Sep 3, 2003.
  1. bangedup
    bangedup Registered Member
    May 17, 2003
    Does any one know if these will fit? My welders NFG so
    need a direct swap.If so is it worth the trouble or should
    I wait for chevy diffs?
    Quoted as posted an a local site.
    Dana 44 heavy duty front axle from 1 ton, 8 bolt pattern, 12" disk brakes, flat top knuckles, passenger side diff. 4:10 ratio, $300
    Dana 60 rear axle, 4:10 ratio, $200
    Both axles are from the same 1980 Dodge 3500 SRW. I'll take $450 for the pair.
    For an extra charge I can do the nessesary machining on the drivers side knuckle to accept high steer arm
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    Hillsboro Oregon
    why is there a 44 in a one ton truck? Yes it will fit.. you need to do a few minor things, you can either spread the springs apart 1/2 inch..... but if i had it to do over aGAIN i would get some bushings from AzKickin offroad that were offset a 1/4 inch on each side... Search for "dodge d60" in this forum and the 73-91 forum... Its been explained a few times...
