Dodge D60 front spindle nut socket size?
Discussion in 'The Garage' started by 78 k5, Sep 23, 2005.
  1. 78 k5
    78 k5 1/2 ton status
    Jul 8, 2004
    261
    Auburn, AL or ATL, Ga
    Anyone know the hex socket size for the spindle nut on a Dodge D60 front? Trying to order one from the local parts store, part # would be great too.
  2. 78 k5
    Jul 8, 2004
    261
    TTT,,,come on somebodys gotta be running one :D
  3. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Not exactly sure what nut you are referring to. I have a Chevy D60, but guts are nearly identical. The tool to remove the wheel bearing retaining nut is a standard 1-ton hub socket. KD tools # 3246, got it from NAPA. The kingpin mounting stud on the knuckle requires a 7/8" allen key. I got mine from Grainger. Dont know of any other special size nut on the axle.
    My friends got a Dodge D60, if you need a measurment of something else, let me know.
  4. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    Dodge and some Ford rears use a standard Nut not a spindle nut like other Dana axles. 2.5" I got one from Sears but it isn't craftsman. OTC 1921 is stamped on it. It is a 3/4 drive though.
  5. 78 k5
    Jul 8, 2004
    261
    I found out...it's actually 2-9/16 :D but I dremmeled out my 2.5 to fit
  6. 6.2puller
    Jul 8, 2004
    569
    New England
    Weird I guess the ford one is different. Unless it is just because my 2.5" socket is a stamped steel thing so it is kind of round in the corners :confused:
