Dodge D60 into a K5
Discussion in 'The Garage' started by SF87K5, Aug 21, 2003.
  1. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    What needs to be done to a dodge D60 to put it into a K5? Any help with this will be very greatful.
  2. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    Talk to mudhead oops I mean mudhog (j/k) he did exactly that and would be a good source to help you. He's cool and a moderator here.
  3. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Az Kickin' makes offset bushing sets for this I think...
    Marv
  4. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    yea if i could do it over again i would go with the bushings as oppose to spreading the springs apart with a hi-lift... ill prolly get the bushings when i get new springs.
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    you can either spread the springs apart slightly or get the offset bushings. you will need a chevy steering arm and a chevy yoke. you will also need the spring plates and new u-bolts. if you have any specific questions just ask /forums/images/graemlins/thumb.gif
  6. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    Aren't the stud diameters and the hub O.D. (wheel center) different than chevy's on some years?
  7. SF87K5
    Oct 27, 2002
    1,105
    Cool thanks for all the good info.
    Now what year dodge D60's are compatable with a K5? Or are they all the same?
  8. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    actually shannon You dont need a chevy steering arm. My friend actually used a Dodge steering arm, on his Chevy D60 so he didnt have to run the 4 inch steering arm block.
  9. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    not sure on years but, Make sure it is not a dana 61 (dont really know how to identify this) If it says "60f" on the lower right corner (maybe left) of the pumpkin then its a 60
    Make sure it is Passenger side diff, And has kingpins, and you will be good to go.
  10. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    why would you want ball joints instead of king pins?
  11. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    oh damn, my bad, thx for catchin that heh. /forums/images/graemlins/thumb.gif
    fixed
  12. SF87K5
    Oct 27, 2002
    1,105
    the dodge is a old dodge military cucv. So I hope it is a 1 ton and not a 3/4 ton. Thats why I was asking about the year.
  13. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    many dodge 3/4T's had a Dana 60 aswell. I've seen a Dodge 3/4HD with a open knucke D70 under it. Odd.
  14. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    Most of the M880s have D44s, but the D60 are out there. Look for king pins, not the 3 u-bolt set up the Dodge D44s also use the 3 u-bolt/2 stud mounting. Also, if there are no bearing hubs (flanged stubshaft) its a D44.
  15. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    mine has drive flanges but it is a dana 60 /forums/images/graemlins/thumb.gif
  16. SF87K5
    Oct 27, 2002
    1,105
    Mudhog you have a dodge d60 under your K5? If so can you take some pics for me so I can take them with me to make sure it is a D60 I am getting. Thanks /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  17. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    yes i have a dodge dana 60 under mine /forums/images/graemlins/smile.gif ill get some pics of it tomorrow /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  18. SF87K5
    Oct 27, 2002
    1,105
    cool thank you
  19. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    no problem /forums/images/graemlins/thumb.gif
  20. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    You also have bearing hubs, or at least you do in all your webshots pics. I said flanged stub-shafts not drive flanges. These are two totaly different arangements.
