Dodge D60 narrower track than Chevy D60 front?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ryan B., Feb 24, 2003.
  1. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Does a Dodge Dana 60 front have a narrower track than the Chevy D60 front? /forums/images/graemlins/confused.gif
    Is the only difference the spring perches?
    /forums/images/graemlins/deal.gif /forums/images/graemlins/ignore.gif /forums/images/graemlins/grin.gif
  2. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Yes, the Dodge axle is about 2" narrower. The spring perches on a Dodge are .5 inch wider. The difference is in the short side axleshaft. It's about 15" on a Dodge, and about 17" on a GM.
  3. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    Check this for all your questions.
  4. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Yep. Thanks dude. /forums/images/graemlins/thumb.gif
    I realized tonight the short side tube is 2" longer on a Chevy. /forums/images/graemlins/shocked.gif
  5. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    I'm in the process of installing one right now. A-Tron is machining the bushings for me to move the springs out so I don't have to pry them apart. /forums/images/graemlins/thumb.gif
  6. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    OK, forgive me if I'm being dense.
    The spring pad distance is 32.5" on a Dodge and 32" on a Chevy. The WMS to WMS on a Dodge is ~67.5" on a Dodge and 69.5" on a Chevy.
    You say the Dodge axle is 15" on the short side (passenger side) and 17" on the Chevy. Does that mean the axle sticks out the same as a Chevy on the driver's side and in 2" inside normal on the passenger side? Or am I missing something?
  7. Ryan B.
    Jul 18, 2001
    5,693
    CA
    No its centered for both.
    The Dodge has a 2.5" wide spring perch mount. The chevy has a 3" wide perch mount. The location of the perch built in the housing is shifted 1" to the left as well as the perch on the long tube, because the short tube side axle is 2" longer: if you want to compare it to a DODGE D60.
  8. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    mine stick out the same on both sides heh,
  9. Langosta39
    Langosta39 1/2 ton status
    Nov 8, 2002
    156
    Moscow, Idaho
    This page is freakin amazing, everyone with a D60 or dreams of a D60 should bookmark this.
    andy
