Dodge D60
Discussion in 'The Garage' started by highrlr, Apr 20, 2005.
  1. highrlr
    highrlr 1/2 ton status
    Nov 29, 2004
    302
    Bismarck, ND
    I found a guy with a '79 dodge 1ton dually 4x4 for sale in my area and his ad says he will part it out so im thinking of buying the D60 front from him. I read a thread a while back talking about using a dodge 60 and if I remember right the spring pads on the the dodge axle were 1/2" wider than the GM axle so you would hafta space your springs 1/4" out on both sides. How would a guy go about doing this? Im thinking on the shackle end to just put a 1/4" think "washer" between the inside shackle and the spring but how do you space the front? Maybe remove the spring mount from the frame and put a 1/4" piece of steel between the frame and mount? Another thing I was wondering about was the steering, would any of the dodge steering work with the the GM setup? And how much should I expect to pay for this axle?
  2. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    The spring pads are closer than that, when i put my dodge 60 in they fit with no problem, you "should" be good to go
  3. highrlr
    Nov 29, 2004
    302
    Bismarck, ND
    That would be awesome if thats how it is, I heard if you "stretch the springs to fit though that you kill your flex and ride? How about the steering?
    anyone else have any info for me?
  4. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Type in "dodge dana 60" in search with my username and you will find a dozen posts on what exaclty needs to be done.
  5. highrlr
    Nov 29, 2004
    302
    Bismarck, ND
    Thanks az-k5, I tried Dodge dana 60 and Dodge d60 as searches an it didnt really come up with anything. I did find some post pertaining to this subject though and i think i found pretty much everything i need to know. Thanks
  6. highrlr
    Nov 29, 2004
    302
    Bismarck, ND
    Ok, one more thing i guess. How much is a '79 Dodge Dana 60 worth? The guy that has this one is asking $900 for it, its not rebuilt or anything and he's not even sure of what gears it has in it. Is it worth this much? I know a GM 60 would be but i thought the Dodges went for a lot less???
  7. sapper
    Jul 11, 2001
    3,052
    NoVa
    The prices are about the same, i would think a dodge 60 would be more because it matchs the rear for width
