DODGE DANA 60- GOOD DEAL?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by purple89jimmy, Sep 9, 2001.
  1. purple89jimmy
    purple89jimmy Registered Member
    May 29, 2001
    75
    Dana 60 Front out of a Dodge, Straight axle, Passenger side diff, Single Wheel, 4.88 gear ratio, Miller Locker, 1 solid hub and 1 lock-out, complete except missing calipers, ready for the Rocks
    .......Corp. 14 Bolt out of Chevy, 3:73 Gear ratio with Posi -- $1,200 for both OBO (will this fit my Jimmy?)
  2. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    I don't know if the Dodge front 60s wiill fut (but I'd like to know if someone has some details). considering the amount of work to match the axles, intstall, parts, etc.. The price is to high. (IMOP)
    <font color=purple>Hi, I'm </font color=purple><font color=blue>Twiztid.</font color=blue><font color=purple> How do you like me so-far?</font color=purple>
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    The Dodge spring perch is too wide.
    Being that the D60 has the spring perch cast into the housing, this is not a usable axle.
    -- Mike
    <font color=blue> At some point I'll be done building my truck and can actually go wheeling. Until then, I guess sex and alcohol will have to do. [​IMG]
  4. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    The axle would work OK, but IMO the price is too high. If it had a locker, then maybe. For an axle that hasn't been gone through, but is complete, I'd say a grand or so. I paid $750 for mine, but it took a long time to find it. By the time I was done rebuilding it and putting in a Detroit, I was right around $1500. If you really want the 4.88s, then maybe. As for the 14 bolt, if you want a detroit then you need a factory open carrier.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  5. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    If anyone needs an 14BFF open carrier, I have one that I pulled 4.10 gears from. I wouls part with it for a reasonable price.
    <font color=red>GOT MUD???</font color=red>
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s
    <a target="_blank" href=http://24.10.209.54/bigolk5.htm>http://24.10.209.54/bigolk5.htm</a> [​IMG]
  6. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    PM'ed you
    <font color=blue>azblazor</font color=blue>
    <font color=orange> 79 K5 454-FI / 4L80E, NP205, D60, FF14, 4" lift, 9K Warn </font color=orange>
