Dodge dana 60 help
Discussion in 'The Garage' started by bigchief427, Dec 9, 2003.
  1. bigchief427
    bigchief427 Registered Member
    Dec 7, 2003
    35
    martinsville indiana usa
    Hey everybody new member. I've got some questions about my dodge dana 60. Its an older 60 out of some military vehicle. 1 The spring plates are they different than gms plates, it seems to be hard to find dodge 60 plates and gm plates are easier to find. 2 i 've done searches and real a lot about the springs and steering arms, WILL the steering arm bolt. I would appreciate any help i can get before i get the sob under the truck to find out whether stuff will work Thanks Matt /forums/images/graemlins/truck.gif /forums/images/graemlins/truck.gif
  2. reeser
    reeser 1/2 ton status
    Oct 8, 2001
    434
    Hayden Lake, ID
    spring plate should work on the drivers side. on the pass side you need a DODGE unit. it has narrower bolts into the housing. steering should hook up ok. you need to put spacers in your shackles to even out the width of the dodge spring perches, they're like 1/2" wider.
