Dodge Dana 60 Rear Question
Discussion in 'The Garage' started by trollporter, Mar 11, 2004.
  1. trollporter
    trollporter 1/2 ton status
    Feb 29, 2004
    518
    Lady's Island, SC
    I aquired a FREEBIE Dana 60 rear from a 71 Dodge D200. If I upgraded from the 30 spline open carrier to a 40 spline Detroit would it be worthy of 44" meat? I know that the 60 is 2" narrower than the SRW 14bFF so what brand of 1" wheel spacers should I run? /forums/images/graemlins/thinking.gif
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    40 spline?
    I run a 35 spline D60 rear w/ 1.5" axels.
    Dunno? D60 rears are perrty tuff but if I was running 44s I would want a full floater rear weather it was D60 or 14bolt. I would not want a SF & 44" meats.
    Good Luck
  3. trollporter
    Feb 29, 2004
    518
    Lady's Island, SC
    It is a full floater, standard pinion, open carrier. As far as I can tell all that i'm going to have to do is move my spring pads to 42.5 C-C and probably roll the pinion up to eliminate the pinion shims. I'm also planing on a 40 spline Detroit w/5.13 and new brakes. I just haven't seen many people running 44"s on a Dana 60 rear and it makes me think that theres a reason for that. /forums/images/graemlins/thinking.gif
  4. Burt4x4
    6,854
    Ya I think the 14bolt is eaiser to get and cheeper to build so most just go that route. I assume with this 40spline locker you are going to get matching axels? I run www.markwilliams.com axels in my Rear SF D60. they are 1.5"diam. 35 spline. Super strong High Torque axels.
    Good Luck /forums/images/graemlins/peace.gif
  5. bluejeep
    bluejeep 1/2 ton status
    Jan 9, 2004
    106
    Des Moines, IA
    Free when it comes to a dana 60 rear isn't that big of a deal. Even if you were to go pay $500 for a 14 bolt rear, you'd be ahead of the game. The money it would take to build your "free" dana 60 rear is much greater than to buy a 14 bolt and run it. Don't overlook things like having new spindles installed that would accept 40 spline axles, or the cost of making it a semi-floater. Add cost of the 40 spline axles, cost of the spacers, cost difference between dana 60 detroit and 14 bolt detroit.... The list goes on and on.
  6. bshewmaker
    bshewmaker Registered Member
    Sep 11, 2003
    79
    Arkansas
    [/ QUOTE ] Why would you want to make it a SF. Seams like your backpeadling /forums/images/graemlins/dunno.gif
