Dodge Dana 60-will it fit?
Discussion in 'The Garage' started by TONYP, Feb 4, 2003.
  1. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    found a Dodge dana 60 from a 91' truck, will this fit a first gen truck? /forums/images/graemlins/k5.gif
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
  3. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    This article should be 60 builders bible.Great job!!Already got it copied for future reference. /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    like any other all encompassing, it has a ton of dodge facts that are not always true.
    my brakes are 1.5" thick for instance.
    great writeup though
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    WMS to WMS is narrower, looks good with wider tires
    springspacing is 1/2" wider, I think offset spring bushings will fix that
    brake lines will bolt up
    wheel studs are smaller diameter, but easy to change
    spring plate mounts differ from chev so get the plates
    there is more...
  6. TONYP
    Aug 13, 2002
    2,116
    so cal
    on the spring plates, do you have to mount your springs in the same place to fit inside the u-bolts, or could I make like zero rate plates and off-set the center hole so on the bottom side the hole matches the axles and on the top side it matches the chevy leaf spring holes?
  7. TONYP
    Aug 13, 2002
    2,116
    so cal
    that write works great,I ran the numbers and the guy had a dana 61 front. Not one that we want to put in are trucks...
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    excellent thinking, as aftermarket springs are narrower then stock chev ones you may get more room.
    pumpkin may be in the way.
    mine was chopped up a bunch so boltin answers are pure speculation on my part.
    did you try searching this comes up a lot here
  9. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    just a side note 94-01 dodge trucks are drivers side fronts. Well the 1500 series anyway.
  10. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    I was emailing Sean at A-tron about the very same thing. He said they would be able to make the offset 'zero-rates' and a u-bolt plate to match. I'll either do mine this way, or machine the bushings to move the springs, as mj has suggested, then work out some type of spacer to place on the side the bushing was machined.
  11. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    TonyP,
    For my model 61 I can get gears of 3.07/3.54/4.10 without changing the carrier. I believe you could run other carriers with a ring gear spacer. Ran into a fella once that had a 1ton ramcharger. Told me the axles originally had 3.07s and he had them geared with 4.88s and detroits.
  12. ZonkRat
    Jan 16, 2003
    1,003
    You can regear 61 with spacer or thick gears.Don't remember where I read it though. I think in Petersons. /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gifer /forums/images/graemlins/thumb.gif
  13. TONYP
    Aug 13, 2002
    2,116
    so cal
    in the write up on Dana 60 they say the Dana 61 is not the one we want to install into our truck...I didn't read the whole post but he said watch out fro the 61... do you know why?
  14. TONYP
    Aug 13, 2002
    2,116
    so cal
    Ok, I just talked to reider gear...he said that you buy a new carrier($75.00) new ring and pinion ($190.00) and your at 4.11's, then if you want to go higer they sell a spacer plate ($47.00) to get you up to 4.88's. next I need to get info on a locker for the dana61...
  15. Diesel Dan
    Feb 27, 2002
    798
    Warren, Ohio
    According to DTS I can use the 3.54 & 4.10 without changing the carrier. But with stock D61 carrier only Lock-rights are available, spider gears are same as D60. If you are going to run the spacer than any D60 carrier/locker will work*.
    *Disclaimer* "SHOULD WORK".
