Dodge Dana 60
Discussion in 'The Garage' started by jwallace1029, Dec 29, 2006.
  1. jwallace1029
    jwallace1029 Registered Member
    Dec 7, 2006
    5
    Arkansas
    Does anybody know if a Dodge Dana 60 will work on an '82 Blazer? Also what is the best transmission transfer case setup?
  2. BoondocK5
    BoondocK5 1 ton status Author
    May 13, 2006
    10,035
    63
    Salt Lake City, Utah
    yeah it will, try the search function on this site. I think it,s just a 1/2 inch too wide, just pry the springs into place. thats the usual method (I think)
  3. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    1" too wide, u need to pry the springs in 1/2" on each side.
  4. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    Non members can't search.
  5. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    Chevy spring pad center to center is 32"
    Dodge is 32 1/2 "
  6. BulldogK5
    BulldogK5 1/2 ton status GMOTM Winner
    Sep 19, 2002
    4,158
    Brandon, MS
    What model Dodge are you lookin' at? I can measure a '99 if you need it, tomorrow if necessary.
  7. jwallace1029
    Dec 7, 2006
    5
    Arkansas
    The guy says it is an '80's model, maybe late '70's, he has a bunch of old 4x4 sitting in his yard.
  8. HoodRich
    HoodRich 1/2 ton status
    Jul 30, 2006
    160
    Kernersville, NC
    I just put one under my '87 Jimmy, with 52's and 7.25 shackles and everything bolted up just fine. I havn't run the BOM on the housing to see what year mine came out off as I wasn't really concerned since its a Kingpin housing.
  9. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
    Does this cause problems or is there a way to fix it?
    Also, is everything else the same? (bolt patterns, brake lines, etc) Any gotcha's to be aware of?
    Does anyone have a good source of information on this swap? I don't want to go pick up an expensive paperweight that won't work or will cost too much $$$ to put under my truck.
