Dodge Dana 70 front axle?
Discussion in 'The Garage' started by OffRoader93, Jan 21, 2004.
  1. OffRoader93
    OffRoader93 1/2 ton status
    Nov 30, 2002
    262
    Is a closed knuckle front axle strong and good? Also on a Dodge Dana 70, what side is the differential on? Would it fit into a Chevy? Thanks.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Closed knuckle is junk.
    Most Dodge's have a diff on the passenger side like a Chevy and the spring pads are close.
    If it's closed knuckle I'd pass though.
  3. OffRoader93
    Nov 30, 2002
    262
    What makes them junk?
  4. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Weak steering joints...
  5. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    smaller u-joints also in the nuckles and leak easily.
  6. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    There's nothing "better" on a closed-knuckle D70 than there is on a D60 except the ring gear size and a stronger differential.
    - turning angle is less
    - uses Tracta-Joints instead of U-joints (non-serviceable)
    - external hubs
    - knuckle seals prone to leak
    - drum brakes
    - freakin' heavy
