Dodge front axles.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by POWERMAD, Aug 12, 2001.
  1. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    This month seems to be my lucky month. The place where I got that 14FF from has an old Dodge 3/4 ton 4x4.
    It has a D44 front that is full time. No hub sticking out just a big nut. The truck is a 77 or 78.
    What would it take to swap it over to part time.
    And will a D44 from a Doge bolt up to a GM. From what I can see it looks the same except for that full time hub.
    I can get the front and the D60 Full floater rear for $200.
    my truck's not dirty, it's earth tone paint
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>The Dodge spring pads are a little closer together than on the chevys so you would have to torch off the drivers side perch and move it. </font color=blue>
  3. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    Wouldn't moving only one perch make the axle off set?
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>You're only moving it 1/2" or less I think. It would be easier just to get a chevy front.</font color=blue>
  5. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    If I could find a GM front axle for that price I would be all over it. Swapping the hubs around might get spendy though. I'll have to look into it some more.
  6. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    my dodge d60 is narrower then a chev by a fair bit as well.
    i wouldnt convert the dodge again
  7. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    Do ya mean that the overall axle width was narrower or the spring perches are narrower.
  8. michaelm
    Feb 2, 2001
    872
    overall axle width AND spring perches
  9. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    Thanx fer the info.
    It is starting to sound like this is gonna be a bigger PITA than it is worth.
    Hopefuly I can find a front axle that someone doesn't think is Gold plated.
  10. michaelm
    Feb 2, 2001
    872
    with wide tires it means less fender flare required
  11. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    That axle is a semi floater, it would take a lot to get it converted, my guess would be a knuckles-out swap. Basically, stay away from it.
    The rear is most likely a 30 spline, which is not much of an improvement over the 12 bolt as far as the shaft dia. If you need a budget rear end, find a 14 bolt. If you do find a 35 spline Dodge rear end, the spring perches are close enough to make it work. I had a buddy that put a 14 in a '77 Dodge.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  12. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    Ugh way to much to swap it.
    I have a 14FF 4:10 I just need a front axle to match.
    And the guy won't sell just the front axle he is selling them as a pair.
    The search continues.
