Dodge knuckles on GM D60?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ryan B., Oct 7, 2002.
  1. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Will Dodge knuckles work on a GM D60?
    What are the differences between a Dodge and GM D60 front?
    Thanks!
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yes, they will work on the GM axle. Matter of fact, Dodge and GM share the exact same part number on the knuckles. /forums/images/graemlins/wink.gif
  3. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Sweet.
    Thanks Wes! /forums/images/graemlins/thumb.gif
  4. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    I take it if the knuckles are the same the spindles and rotors and hubs and calapers should be the same too???
  5. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    The hubs are different. Most Dodges run an external drive flange or lock out. Simular to the early 44's. GM 60's are internal. Otherwise interchangeable.
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yes, all are the same EXCEPT for the bearing hubs.
    Dodge did have the external bearing hubs, but those are on the older D60's.
    The newer Dodges, don't know exactly what years, have all internal bearing hubs.
    ALL GM D60's are the internal bearing hub design.
    The big difference between the Dodge and GM bearing hubs are the shape of them.
    Dodge hub is more a straight-shape whereas the GM hub is more an angled shape.
  7. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    CHECK IT HERE
    Hi-jacking this thread for a good cause! /forums/images/graemlins/smile.gif Check this out for pics and such... my axle is Dodge, with Ferd outters. But I am more concerned about getting the lower bearing race out. Can anyone here help me out?
    Thanks,
    -Dan
  8. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Just for trivia's sake /forums/images/graemlins/grin.gif
    '91 Chevy crewcabs (91 only for some reason) have the straight (cylindrical) hubs like the Dodge rather than the tapered ones found on most K30's.
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    Can't help you here as I've never seen a '90 or '91 V3500 up close. /forums/images/graemlins/frown.gif
  10. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    Ooooo! Cool info, I just bought a 91 but I didn't pay attention to the hub shape - I've got to go home and look at it closer (HURRY UP 4:30!!).
  11. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I think it is like the knuckle differences,
    a design change at Dana where everything made after X date gets new design
    I would be cautious switching 1 knuckle, make sure details are the same as there is documented differences on this site now that Wes is ignooring for some reason
