dodge rear end
Discussion in 'The Garage' started by 69K5, Jan 19, 2004.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    my friend aquired several old dodge miltary trucks. he said one of them has a full floating rear end and i can have it. its a 1976 w200. any idea what rear end it is? im guessing maybe a dana 60?will this work in my blazer? i can move spring perches without a problem.
    thanks
    69k5
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    free??? get it
    it will be something good, cant be worse than a 12 or 10 bolt!
    ge tit now and find out later all about it
  3. gmule
    gmule 1/2 ton status
    Apr 2, 2002
    196
    Conifer Colorado
    It should be a Dana 60 with 4:10 r&p
  4. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    gmule
    any idea on spring perches on these? If its 4.10 i am gonna have to swap gears somehere. i have a full set of 3.73 and 4.56 front and rears but no 4.10's. im assuming you can get something in the 4.56 range for a d60. i may swap my d44 4.56 front with someone for some 4.10's just have to wait and see.
    randy
    thats exactly what i thought. if nothing else it can be under a trailer.
    thanks for the info
    69k5
  5. DougK20
    DougK20 1/2 ton status
    Feb 18, 2003
    384
    Boise, ID
    Also, look into the rear lower shock mounts. I've often wondered why we don't utilize them on our GM's when converting to inboard /\.
  6. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    doug k 20
    i dont quite get what you mean??
  7. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Probably because they hang under the axle....
  8. gmule
    Apr 2, 2002
    196
    Conifer Colorado
    gmule
    randy
    thanks for the info
    69k5
    Center to center the spring perches are 44 1/2" apart
    WMS to WMS is 65".
    There is a carrier break at the 4:10 ratio 4:10 down and 4:56 and up.
    as far as shock mountins hanging down most of the Dodge guys are flipping the u bolts and welding a shock mount onto the axle tube.
