Does a 2wd rear axel fit a 4wd ?????
Discussion in 'The Garage' started by Supreme70, Nov 14, 2005.
  1. Supreme70
    Supreme70 1/2 ton status
    Jan 19, 2005
    501
    Detroit, Mi
    I need to know if a 2wd rear axel fit a 4wd ?????
  2. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
  3. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    might end up with 5 lugs in the rear, and 6 up front.... :confused:
  4. guido666
    Feb 16, 2005
    788
    Longmont, CO
    <EDIT> :doah: IGNORE THIS, I'M STUPID :doah: </EDIT>
    The narrow rear would help turning radius, might cause more rollovers too. :crazy:
    <EDIT> :doah: IGNORE THIS I'M STUPID :doah: </EDIT>
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    No . I have used a 12 bolt 2wd truck axle in my truck , and its under my project now . 4wd axles fit perfectly . Not skinnier than a 4wd at all :D
  6. guido666
    Feb 16, 2005
    788
    Longmont, CO
    Sorry, I'm an idiot, that was meant for the "Can I put a car 12b in my truck" thread. I have more then one window open.
  7. lrazer
    lrazer 1/2 ton status
    Oct 3, 2004
    231
    Mokena, IL
    my 14ff was outa a 2wd works fine there isn't any difference
    on a 1 ton the spring pearches are narrower tho but u just have to cut off the pearches and reweld them no biggie
  8. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    767
    Granbury, TX
    the only difference (on 8 lug 3/4ton models anyway) is shock mounts
    2wd they hang lower, and may cause shock body to hit axle tube at droop or when using blocks/shims to correct pinion angle
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I forgot to mention that with the shackle flip , and a 2wd 10/12 axle , the shock hits . I have seen others with shackle flips that didn't have to do it . But with my 2wd 12 , I run that shock upside down :D
  10. lrazer
    Oct 3, 2004
    231
    Mokena, IL
    i forgot about the shock mounts too
    on mine i remounted them with the point the shock bolt rotated on the axle so that they are straight forward and straight back instead of hanging down below the axle
    this helped with axle wrap as well
