does a 4" lift kit need steering correction w/ stock steering?
Discussion in 'The Garage' started by RampageFSJ, Jul 7, 2006.
  1. RampageFSJ
    RampageFSJ 1/2 ton status
    Aug 18, 2005
    121
    Ulysses KS
    I've been saying a lot lately that I'm helping a friend and we have a 4" lift on a parts truck that we can get for his Blazer, and I have another question. I looked at the truck with the stock height Blazer nose to nose and noticed that the pitman arm and the arm on the knuckle of the parts truck look like they are stock. Can a rig run without steering corrections with a 4" lift? Or did the PO on the parts truck skip out on the steering when he lifted it? If it "kinda" works, that would be allright. He's going to go with crossover steering shortly after it's lifted with all of those problems figured out if I have any say in what's going on with it:wink1: .
    Many thanks in advance.:waytogo:
  2. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    you need steering correction. you won't be able to turn in one direction - i forget which. i think it's left. your turning radius would be about a mile in the left direction.
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    You can get away without a steering correction but you will definately need to readjust the drag link or it won't steer as far in one direction as the other. Sometimes you run out of adjustment making it nessecary to install a steering correction device of some sort.
  4. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    On my 77 K10 I just adjusted the draglink, and it didn't turn that great, but I could live with it.
    On my 84 K5 I used a raised arm and it was like stock, awsome turning radius in both directions.
    Both had 4" suspension lifts.
  5. jolane
    jolane 1/2 ton status
    May 27, 2004
    132
    Yeah, I too have a 4" lift, and had a raised steering arm. It still turned better to the left than the right even with the arm, but was MUCH better than stock. With that said, I just went to a D60 and cross-over, and have a raised steering arm "left over". Someone is coming for the axle set tomorrow, but does not want the steering arm. If interested, make an offer. I may also have VERY low miles (less than 600 probably) draglink sleeve and TRE's to go with it. I will know more Sunday after the axles are picked up.
    Please use PM if interested. Sorry for the hijack...
    Joshua
  6. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
    Could just do crossover at the same time as lift and not worry about it.
