Does anybody have a set of....
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by HarryL, Apr 1, 2001.
  1. HarryL
    HarryL 1/2 ton status
    Feb 25, 2001
    139
    Layton, UT (20 miles north of SLC)
    6" rear lift blocks for my 72? Right now I've got stacked blocks and ain't too keen about that idea.
    No blocks? How about a set of 6" rear leafs?
    No rear leafs? OK, then what material can I use to make some blocks? I was thinking 3" (2.5"?) wide by 6" high by 6" long 3/8" bar stock......
    Any recommendations?
    Horse traders welcome.
    Harry
  2. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    Why don't you do a shackle flip and give yourself four inches, then use 2" blocks or longer springs.???
    just a suggestion
  3. 1_FN_HI_K5
    1_FN_HI_K5 Registered Member
    Dec 31, 2000
    22
    Does your blazer need a true six inch block? They make a 5.5
    inch block for under $50.00. I have them under mine with the top on the truck sit's level.
    1 FN HI K5
  4. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    I started a post similar to this in the '73-'91 forum the other day. You may want to keep an eye on it.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  5. HarryL
    Feb 25, 2001
    139
    I reckon I could do a shackle flip. l did it on my other 72 Blazer. I just don't feel like breaking out the cutting torch and cutting holes again. Lazy I guess.
  6. HarryL
    Feb 25, 2001
    139
    Who makes a 5.5 inch block for under $50.00?
    Could you please give manufacturer name and a #?
    Thanks. This is right about my speed. As for 6", That was only an eyeball estimation (plus the front end has 6" superlift springs in it!)
    Harry
