Does anybody have pics of their HP60 ubolts
Discussion in 'The Garage' started by cybrfire, May 9, 2004.
  1. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    Post them up if you got some just curious what they look like all assembled if you kept them threads down. If not what did you do? Could make some plates and use regular ubolts. Still making up my mind.
  2. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    I wanted to get the threads on top for ground clearance so I made plates for mine. I used ubolts on the pass side (threads up). On the drivers side I used the ford molded block under the pumpkin and axle with 5/8" Grade 8 bolts also with the threads up. Not the best pics but you get the idea [​IMG]
  3. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    How come you went with bolts and the ford plate rather than a u bolt set up. I'm thinking about notching a web or something and using 4 ubolts.
  4. Stomper
    May 11, 2002
    3,767
    Iowa
    I didn't want to take any metal away from the casting and it was easier to use the block /forums/images/graemlins/whistling.gif
  5. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    I guess it's not a clearance issue with it being that close to the pumpkin. Threads up is good though.
  6. Stomper
    May 11, 2002
    3,767
    Iowa
    True the block takes away some ground clearance but the threads were my main concern.
  7. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Pass. Side:
    Drivers Side:
  8. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    On the drivers side did you notch the web on the bottom to keep the ubolt from sliding when tightened?
  9. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Is this what you want? Heres one, sorry if its not that good though.
    The bottom pass side is just the stock plate type thing, welded to the housing and the drivers is the plate that goes around the pumpkin.
