Does Anybody know the tap size of an O2 Sensor?
Discussion in 'The Garage' started by Mudzer, Sep 13, 2002.
  1. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    I have a friend with a Z71 Truck and the Oxygen Sensor bung is stripped out on the exhaust pipe. Since I dont have a welder nor the time to mess with this much I need to find a tap to chase the threads, then install the new 02 sensor. They appear to be 1/2" diameter and I would assume they are NPT. I found Granger has a tap which is 1/2" and a pitch of 14. Does anybody know the exact specs on an O2 sensor so I can buy the appropriate tap?
    Thanks,
    Neil
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    1/2 " diameter would equate to 1/4" NPT, but without seein' it I can't say for certain. Hope this helps.
    John
  3. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    I'm not sure of the actual thread pitch but I know they're not pipe thread cause the sensor has a crush washer on it that bottoms out on the bung. You should be able to measure the threads on the new sensor. There's a very good chance they're metric too, since most engine components are these days.
  4. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    There are unversal o2 sensors out there with self cutting threads.
  5. Mudzer
    3,639
    Missouri
    Ok, I borrowed a tool from a local shop. THey said this O2 has the same threads as most commmon spark plugs. It looks right, so I will compare threads then clean the bung-hole. /forums/images/icons/grin.gif
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, it is the size of most spark plugs. So it sounds like you're on track. /forums/images/icons/cool.gif If the bung is totally wasted, you can go to a decent hardware store and buy a hex nut that has the correct threads. Then split the nut in half with a bandsaw or cutoff wheel and weld one half to the exhaust pipe. That's how I made the one that's on my K5 and it cost something like 40 cents instead of the $8.95 that most places want for a ready made weld-on bung.
    Don't forget to dab some anti-sieze on the sensor threads before re-installing the sensor. Makes it much easier to change next time. /forums/images/icons/cool.gif
