Does anybody know
Discussion in 'The Garage' started by 1972J, Aug 11, 2005.
  1. 1972J
    1972J Newbie
    Aug 11, 2005
    Texas
    How many 1972 GMC Jimmies were built or how many 4x4's were built in that year.
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    On the main www.coloradok5.com homepage, hit the "Speficications" link.
    All the build numbers are there for these trucks.
    Welcome.
  3. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    Year:: 1972 Production Total: 44,266
    Base Price: 3,145 Weight: 3,677
    Wheel Base: 104 in. Fuel Tank Capacity: 23.5-gallon
    Length: 177.5 in. Height: 68.7 in.
    Std. Engine, (net HP):
    OHV Six-cylinder 250 cid. (110) @ 4000 rpm
    Opt. Engine, (net HP):
    OHV Eight-cylinder 307 cid. (135) @ 4000 rpm
    OHV Eight-cylinder 350 cid. (175) @ 3600 rpm
    Rear Axle:
    GM Corporate 12-bolt (8.7/8-in. 1.31 Axle Dia. 30 Spline)
    Front Axle:
    Dana 44 (8.5-in. 1.31 Axle Dia. 30 Spline)
    Transmission (M):
    SM318/SM326/SM330/T-89A/T-150 3 spd. (2.47-3.50:1 First Gear)
    SM465 4 spd. (6.55:1 First Gear)
    Transmission (A):
    TH350 (2.52:1 First Gear)
    Transfer Case (M):
    NP205 (1.96:1 Low Range)
    Dana 20 (2.03:1 Low Range)
    Transfer Case (A):
    Notes:
    Blazer's, looked similar to the previous year's model, except that the border of the grille surround was no longer black-finished.
    The Blazer's single-unit body was joined to a heavy channel steel frame and had a completely removable fiberglass top.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    oh and BTW 250ci was the base KS model engine and 307 was the base KE model engine
    model codes*
