Does anybody know...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by txbartman, Dec 26, 2001.
  1. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    If a 1984 Silverado swb pickup came with the same 28 spline 10-bolt rear end as the K5/Jimmy's?
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  2. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I would think that it woud be the same diff...
    <font color=red>GOT MUD???</font color=red>
    My license plate reads:<font color=blue> 8 YR SUV</font color=blue>
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s - 36" TSLs
  3. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    yes, it is the same diff as long as if is 4wd the 2wd diffs are a bit narrower, but only by a little bit, the 2wd will bolt up, but then you have a 5 bolt pattern unless you change axle shafts and then that is where the difference come into play, but I believe a 4wd shaft is only maybe a 1/4 inch longer or so, so it could still work, maybe?????
    it is always easier to ask for forgiveness than permission
