Does anybody now what trans is in a 93 GMC
Discussion in 'The Garage' started by gokartergo, Aug 28, 2002.
  1. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    93 GMC 1/2 ton pickup with the V-6..2wd... The 5 speed one.. I am not sure of what model it is...Thanks
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    OK I found out what it is.. It is a MG5.. Does anybody know if this can be bolted up to a 350.. Is it strong enough?? And do they make a shaft to go to a 203 or 205??
  3. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    if its a two wheel drive it might have a long tailshaft which would mean it probably cant be bolted to a t-case
    without modifications of course
    Later
    btw...the shirt has been ordered...it should go out in a couple weeks
  4. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    But it doesn't look any lomger then a th350
  5. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    maybe im wrong...i know a buddy of mine had a two wheel drive truck with a th400 but i couldnt use it unless i changed out the tailshaft and all that cuz it was real long
    Later
  6. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I figured I would have to change shafts.. But is this possible.. Man that is a good tranny behind a V-6.. It has a real low first gear and a overdrive for 5th..
