does anyone else have springs longer then the 52's up front?
Discussion in 'The Garage' started by 55Willy, Apr 14, 2004.
  1. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    does anyone else have springs longer then the 52\'s up front?
    anyone?
    what did you use?
    pics?
    I used 57's up front. off of a 77 ford
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Re: does anyone else have springs longer then the 52\'s up front?
    I think Blazinzuks are longer. He used some Dodge springs and built his own mounts.
    A few weeks I guess you can see them for yourself. /forums/images/graemlins/thumb.gif
  3. rcurrier44
    rcurrier44 1/2 ton status
    Oct 13, 2003
    320
    I used the ford 57" leafs too. Mostly did it to get the wider leaf so I hopefully won't bend another main leaf...so far so good.
  4. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    2.5" wide is 2.5" wide /forums/images/graemlins/confused.gif
    or did you use the 3" wide ones?
  5. rcurrier44
    Oct 13, 2003
    320
  6. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    the 3" I have here are actually a hair over 3, more like 3.25 so the u bolts didn't fit around them with out having to gring a groove for them to run through. so I put the 2.5" back in. my front mount is lowered like 2" lower then stock and i also used a 7" shackle and I gained about 9" of lift. Also running a 8* shim. Axel is moved about 5" forward.
  7. rcurrier44
    Oct 13, 2003
    320
    I think mine were a little wider than 3" also. I simply modified my top plates so I could get some u-bolts to fit...making new ones when I get the 60 under there.
    I used a 7" shackle but moved my frount mount up 3.25"...gave me 4-5 inches of lift.
