does anyone have a book on carb #'s I need help please?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by slider79blazer, Aug 31, 2001.
  1. slider79blazer
    slider79blazer 1/2 ton status
    Mar 23, 2001
    164
    littleton,co.
    does anyone have a book on carb #\'s I need help please?
    I got a 79 K5 with a 400c.i. the carb is a rochestor Q-jet. I tried to get a rebuild kit but the numbers don't match anyones books. the two numbers I got off of it were <font color=purple>17058940</font color=purple> this was on top of the carb second was <font color=purple>17061829</font color=purple> this was on the body on the back of the carb. A friend at work says this carb doesn't look like the one that came with a 79. Also has the hot air choke any help greatly needed. Thanks.
    <font color=purple>whats a 4 letter word for farm wagon?</font color=purple> <font color=blue>ford</font color=blue>
    <a target="_blank" href=http://community.webshots.com/user/slider79blazer>http://community.webshots.com/user/slider79blazer</a>
  2. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    Re: does anyone have a book on carb #\'s I need help please?
    I got this link from a post on here a while back, it should give you the info you need http://www.dorianyeager.com/qjetid.html
    Check out my 73 K5 <a target="_blank" href=http://members.theglobe.com/xnoahx/73k5.htm>http://members.theglobe.com/xnoahx/73k5.htm</a>
  3. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Check out My 85 Jimmy
    Who put a stop payment on my reality check?!?
  4. slider79blazer
    Mar 23, 2001
    164
    littleton,co.
    Well I checked out both sites and neither one had these numbers either. thanks for the help though. I'm beginning to wonder if someone just pieced this together from different years.[​IMG] [​IMG]
    <font color=blue>whats a 4 letter word for farm wagon?-- ford</font color=blue> [​IMG]
  5. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
    thats what it sounds like to me too because i tried to decode it and i couldnt figure it out the numbers didnt match
  6. CAROLINAK5
    CAROLINAK5 1/2 ton status
    Aug 2, 2001
    242
    lexington, north carolina
    tje model numbers should be stamped on the tower right behind the throttle linkage. i'll check the rochester book by david roe for more info.
  7. slider79blazer
    Mar 23, 2001
    164
    littleton,co.
    I looked on the sides where the stamp is in the books but there is nothing. the numders that I found were in little circles. the only other #'s I found was on the bottom plate <font color=blue>60598</font color=blue>. I talked to a guy at the store he found a kit real close to one of the numbers he said it should work and is a common kit. hopefully it will work I've never rebuilt a q-jet before is it hard to do?
  8. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Neither number is listed in my book, Chevy V8 Engine Casting Numbers.
    There are a unch of numbers very close, and they are from 79. They go in order, so my guess is the carb IS from 79, but that's all I can tell you about it.
    Take photos or draw pictures as you go, there's a lot of parts in there.
    Lift It, Lock It, LIVE IT!!!
  9. 79Jimmy
    79Jimmy 1/2 ton status
    May 10, 2000
    214
    Richmond BC, Canada
    I can tell you that my buddies 79 Suburban with a 400 has Q-Jet model number 17059226. Its the number STAMPED into the divers side of the carb main body, vertically. Right behind the secondary linkage.
    79jimmy@home.com
  10. slider79blazer
    Mar 23, 2001
    164
    littleton,co.
    Thanks everyone for the help[​IMG]. I bought a kit for a 79 and it did fit. there were no numbers on the side they were ground off for some reason. but I took the old gaskets and carb in with me and found the right kit. It runs GREAT now. thanks again.[​IMG][​IMG]!!!!!!
