Does anyone have a closeup pic of a 75 door frame?
Discussion in 'The Garage' started by CK5, Jul 12, 2003.
  1. CK5
    May 19, 1999
    21,627
    704
    CO
    I need a pic of a 73-75 upper door frame where it meets the top of the windshield frame, prefer a pic with the door cap (moulding) off if you have one.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I can get you one really fast off my burb, or are you looking for the convertable part?
  3. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    FINALLY!! I can actually help someone out on here (and it just happens to be da boss /forums/images/graemlins/tongue.gif)
    If this isn't what you want, I can go take more.
  4. CK5
    May 19, 1999
    21,627
    704
    CO
    Sweet, that 2nd one is better, can you get a pic directly from the side? I need to know where to make a cut. /forums/images/graemlins/thinking.gif
  5. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Uh oh....I see the UAV going full convertable /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  6. 75-K5
    Apr 28, 2002
    5,353
    Anderson, Indiana
    I think this is what you meant. I took a few more so you can see where some other cuts might need to be made.
    /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif DISREGARD MY FAT SHIRTLESS ASS IN PIC #3!! /forums/images/graemlins/1zhelp.gif
  7. CK5
    May 19, 1999
    21,627
    704
    CO
    OK, that first pick is good, looks like it does not get cut straight accross. Is that a stock 73-75 door? looks like the part by the door handle is a little high? Thanks for taking the pics. /forums/images/graemlins/thumb.gif
  8. 75-K5
    Apr 28, 2002
    5,353
    Anderson, Indiana
    No, the guy that had it before me used pickup doors and cut them.
  9. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Looks like someone else allready nailed it. But this is what I got
    Pic one
    Pic two
  10. Bigmeats
    Bigmeats 1/2 ton status
    Jul 29, 2000
    523
    Manhattan IL
    My buddy has stock doors still on his 75, wich is where i took my template from. If you are still in need of pics let me know i can run over there and take a pic for you.
  11. Grim-Reaper
    7,385
    Atlanta
    It really would help to have a door to measure. The cut is at a goofy angle.
    See if Denver75's still got his rolled body around where you can get some measurments.
  12. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    I had an original door off a 74, and the upper cut was in line with the vent window frame, not at an angle like that. The handle side was lower too. Unfortunately the door went with the 74 when I sold it./forums/images/graemlins/frown.gif
    Since when do you run doors anyways?
    Rene
  13. Bigmeats
    Jul 29, 2000
    523
    Manhattan IL
    The orignal door on my friends 75 is cut at two different angles like in the first pic,the angles matched perfevtly with the piller cover i bought and the one on his truck.
    .....hmmmmmmm..... /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
  14. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    I had a '73 blazer that I put doors off of an '84 truck on.The cut above the vent looks alright but the cut above the handle is high.The cut above the handle follows the window line straight across.The window tracks are different as is the window it self.The track bolts just above the handle and window has an extra piece of metal that rides in the track to help secure it.
    Without getting the right parts you will have to cut the door like is shown.
  15. CK5
    May 19, 1999
    21,627
    704
    CO
    Can anyone confirm that this is the same cut on a stock 73-75? [​IMG]
  16. 75-K5
    Apr 28, 2002
    5,353
    Anderson, Indiana
    I can confirm that the molding piece that goes there fits just fine and it doesn't leak (at least at that location /forums/images/graemlins/rotfl.gif). I can measure it tomorrow if you need more exact specs. And yes, the cut on the door is too high, and the retarted P.O. decided to hack a small piece of the top off instead of fixing the cut on the door, so now my top is no good if I try to use it with the correct doors /forums/images/graemlins/angryfire.gif
    That's about all I can tell you though /forums/images/graemlins/crazy.gif, I'm sure it's not exactly the same as the stock doors, so you'd probably be better off having someone else check.
  17. Bigmeats
    Jul 29, 2000
    523
    Manhattan IL
    Here is a pic of the stock door
    I also made you a pattern if you want it
    carl
  18. CK5
    May 19, 1999
    21,627
    704
    CO
    Yeah, you have a pattern? /forums/images/graemlins/thumb.gif
  19. Bigmeats
    Jul 29, 2000
    523
    Manhattan IL
    Sent you a PM
