Does anyone have a D44 w/ top mounted tie rod
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BozoWise, May 15, 2002.
  1. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    I have a top mounted tie rod on my Dana 44 and it has the tie rod with only one removable end on the pass. side both ends feel sloppy and I would like to replace them. Do I have to buy a new rod since the drivers side does not unscrew from the rod? Can I use my 10 bolt tie rod on the 44? When did chevy put this type of D44 on Subs? It has the top mount tie rod, should have come from the factory with full time hubs, has the threaded strap on the diff u-joint instead of the strap with bolts setup.
  2. rock.monkey
    rock.monkey 1/2 ton status
    Oct 28, 2000
    296
    100 Mile house B.C. Canada
    My '73 3/4 ton 44 has top mounted tie rods and I used my old ones from my '88 10 bolt with no problems.
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    My '71 Sub has top mounted tie rod ends. It has the tie rod with two threaded removeable ends.
  4. ddtoby
    ddtoby Newbie
    Oct 24, 2001
    3
    Colorado Springs, CO
    My 8 lug Dana 44 is from a '74 J**P J20 and it is also top mounted, it also only has the one side that you can unscrew, the driver side. I had to cut the passenger side TRE bolt off in order to remove it from the knuckle and am thinking that I am going to have to buy the whole TRE with the long tie rod also. I am hoping just to find a used tie rod from the pick a part place to replace it with.
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
  6. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    The front has 4.09 gears and the rear is a 4.10 is that ok to run fulltime four wheel drive with the gears not matching?
  7. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Yes, it is fine. In fact it is as close as you will be able to get w/ those axles. You have two different ring gear sizes so it would not be feasable for them to be exactly the same.
  8. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    Can I use a 10 bolt tie rod (has the 2 removable ends on the top mounted 44? If so how would I rig a steering stabilzer since the mounting point on the axel is different?
