Does anyone have instructions to convert a/c to Onboard Air Compressor?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chrome Moly, May 22, 2000.
  1. Chrome Moly
    Chrome Moly Registered Member
    59
    Cheesehead Wisconsin
    I was wondering if anybody had step by step instructions or web links, on converting my a/c compressor to an on board Air Compressor. Thanks a-mill
    Chrome Moly
    <font color=green>Resistance is Futile</font color=green> [​IMG]
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
  3. smack
    smack 1/2 ton status
    Feb 24, 2000
    277
    Colorado
    Hey I looked for it but couldn't find it.
  4. Burt4x4
    6,854
    Opps...That was for an onboard welder not a compressor![​IMG] sorry, i'll keep looking....
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
  5. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
  6. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I take it if you convert it the AC doesn't work anymore?
  7. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    White Knight has a sweet one on his truck. Try sending him a message on this.
    [​IMG][​IMG]
    Durant, Ok
    '79 Blazer in progress
  8. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    Take high pressure line and plumb a quick disconnect on it, take suction line and instal a homemade filter system, purchase one switch wire hot lead to compressor clutch through switch and other to a ground, purchase a 180 pop-off valve and put a 1/4 male disconnect on it... put pop off in when ever you're not using the compressor, that way if something happens and the compressor comes on it won't blow lines or cradle the compressor...turn on switch and presto air.....oil the the compressor every 20 hours of run time or so with a non-detergent oil.
    White Knight
  9. Chrome Moly
    59
    Hey Thanks White Knight, do you have any pics of your setup.
    Oh by the way when your not using your Air, the engine's belts are still turning the compressor, do you still have to lube the compressor and where do you put the oil?
    Chrome Moly
  10. Bigd
    Bigd 1/2 ton status
    Apr 3, 2000
    399
    Co,Colorado Springs
    was just on rockcrawler.com they have a nice two part article on using a york ac compressor for on board air.
  11. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Does this mean doing without A/C? Or adding an additional compressor to facilitate the air supply system?
    <font color=green>[​IMG]Eagle86K5[​IMG]<font color=red>
    Masonry...It's a Good Thing
    2B1ASK1
