Does anyone know anyone that is running a newer truck with...
Discussion in 'The Garage' started by ZfromNJ, Oct 6, 2004.
  1. ZfromNJ
    ZfromNJ Registered Member
    Jan 26, 2001
    99
    New Jersey
    I am looking to run a newer truck (1990 K5 Blazer) to make it a full convertible? Does anyone know of anyone out there that has this. Or what about a 73-75 k5 blazer with all newer interior. Electric windows, and door locks, dash, thew works.
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Steve(the owner of this site) is running a 90 K5 with the top cut off. Plus there are alot of guys on here that are running the 76+ K5's with the tops cut off. I imagine there are some running the other way like you say with the pre75's running newer interior.
    To make a 90 full vert, you need to hack the roof, install a pre 75 windshield frame, cab the rails where the old roof was cut from the 1/4 panel(right behind the doors) and cut the top rails off your doors(and cap that also).. Thats a brief overview. /forums/images/graemlins/smile.gif And it would be best to add a cage or some type of body supports since the newer body tubs are not supported to be full 'vert... Older K5 that were fromt he factory full vert had extra supports under the tub..
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I like the look of the "newer" motel blazer, with the different headlights. Its really not thta hard to make it full conv. are you wanting to use the full top also or convertable all the time?? If you want to use the full top just get the windshiled frame off the old blazer and weld it in place the EXACT same was on the new blazer. Hope this made sense. /forums/images/graemlins/thumb.gif
  4. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    ahhh beat me to it /forums/images/graemlins/angryfire.gif
  5. ZfromNJ
    Jan 26, 2001
    99
    New Jersey
    Thanks Fellas. I think I might want to run a 73-75 blazer and just update the interior. I think the converting a newer blazer into a full convertible may be a bit too hard for me, but that would be Ideal. Does the second generation blazer compatible with a newer blazer interior or is ther a lot of modifications there too. Does anyone know of anyone that converts a 90ish blazer into a full convertible. I would be willing to pay for the services.
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    I think Yunit is over in Jersey. You may want to ask him if he'd help... Or I am sure any body shop could do it....
    As far as the interior goes... The seats and all should swap. The door panels are a little different on the older K5's, but they may swap also. The dash, however, is a slightly different style wiht the older one being shallower around the gauages than the newer ones. And the carpet will fit the front, but the older k5's had a different rear floor design and the newer carpet wont fit the older(<76) since the floor wells where the passengers feet go are different..
