Does anyone know if this engine will pass CA emissions???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigblue, Mar 14, 2002.
  1. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    SD330VTBI 330 HP Vortec TBI Truck Engine Assembly 330HP 375 torque
    scoggin dickey parts center
    thanks...
  2. Stomp
    Stomp 1/2 ton status
    Feb 23, 2002
    168
    Hill Air Force Base Utah
    Has to have all the smog stuff. Compressor, heat riser, EGR, Vapor recovery canister, cats and alot of other BS. I used to live in CA and thats one of the reason I moved
  3. bigblue
    Dec 6, 2000
    658
    southern california
    I would basicly be swapping it on my 87 that has all the smog stuff...So it would be OK?
  4. Stomp
    Feb 23, 2002
    168
    I would think so.
  5. Headbanger
    Headbanger 1/2 ton status
    Nov 29, 2001
    123
    Moreno Valley, California. U.S.A.
    If the engine you are putting in was an option for that vehicle or the same cu.in. as the engine coming out it should be ok as long as all the smog is there. If the engine is a totally different engine than was offered that year you will need to go through a Bureau of Automotive Repair referee to make sure the right stuff is on it.
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    It will pass fine. A new motor (even a HP motor) will put out less smog than a old motor.
    JUST DON'T TELL THEM!!!!
  7. tmanofcali
    tmanofcali 1/2 ton status
    Mar 20, 2001
    372
    lodi, ca
    no that motor will not pass according to the referee up here in nor. cal. . the vortec heads is what the problem is. you may want to call your local referee and ask personally, but thats what they told one of my friends. check it out before you do order it. i lucked out ....i have a 72 ...no smog for me.....if they ok it i would recomend that motor. thats what i have in mine and it moves good.later.....tmanofcali
  8. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    That is the problem...you asked them...
    Vortec heads burn cleaner than the stock heads!
    My theory:
    It is easier to get forgiveness than permission!
    What comes out the tail pipe is what the smog tech. guys will be worrying about...and stuff like your fuel cap, vacume lines, timing, etc... If you don't anounce "I have a modified motor" (like by puting on all that crome stuff) they won't care if it looks stock. Do you think the smog guy can tell the difference between your stock heads and vortecs?
  9. tmanofcali
    Mar 20, 2001
    372
    lodi, ca
    i bet they know that center bolt valve covers werent stock....that might make them picky. i dont know about the smog shops in your area, but here they look for that stuff. im just glad i have a first gen so i dont have to worry........lol
    i just dont want to tell him "yes , go for it!!' and then he gets in trouble for it not being legal and gets pissed at us. better safe than sorry....just my opinion
    later......tmanofcali
  10. hoserr
    hoserr Registered Member
    Jul 25, 2001
    78
    chula vista, ca
    yes, it'll be a direct engine replacement. trucks have very lenient smog requirements so it'll pass legally.
  11. bigblue
    Dec 6, 2000
    658
    southern california
    You know I am starting to get sick and tired of you 72 fellows always rubbing it in...It is a consistent thing around here....hehe Maybe I should join ya.........
    There is another engine that is about 1000 bucks less expensive without the Vortech heads that puts out 300 / 350...I could go that route, but the Vortech heads are just plain cool as hell...
  12. 87GMCJimmy
    87GMCJimmy 1/2 ton status
    Nov 21, 2001
    582
    Phoenix, AZ
    Just so ya know center bolt valve covers are stock on an 87. This is the first year for them and the TBI.
  13. tmanofcali
    Mar 20, 2001
    372
    lodi, ca
    i thought 88 was the first year for them.....sorry my bad.
    is what i would do is get to know a local smog guy and hopefully he likes you enough to not check the numbers onthe block. i had another friend that put in a stock 350 crate motor in a 74k5 and he had to go to the referee and even he wasnt gonna pass it because one hose was heater hose instead of smog tubing.he told us if we get some smog hose on there he will pass it. we looked everywhere for the hose......nobody had it. not even smog shops. so we went and bought a 1 foot chunk of heater hose and cut it just right so there was no wording on it. took it back and showed him and he said thats fine.......lol.
    all im saying is the california smog guys can be real picky if they want to be. they can fail you even if the truck passes with flying colors. they did to my friend. also remember that they check your gas cap now so make sure its in good working order.
    good luck on the project!!!
    later........tmanofcali
  14. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    Maybe this site will help ...
    <a target="_blank" href=http://www.arb.ca.gov/aftermkt/aftermkt.exe> CA arb engine change</a>
