Does Anyone know the difference in weight from a 350 sb to 454 bb
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Jeremy, Aug 15, 2002.
  1. Jeremy
    Jeremy Registered Member
    Feb 13, 2002
    17
    Price, Ut
    Hi, Just wondering how much more a Big block weights than a Small block. Also does a 400 cubic inch small block weight more than a 350 cubic inch small block? I am thinking of shedding pounds. /forums/images/icons/laugh.gif Also on a pipe dream how much does an aluminum 454 weight?
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    400 weighs about the same as the 350 since they are both SBC's.
    The BBC weighs approximately in the range of 125 lbs. more than a SBC.
  3. Jeremy
    Feb 13, 2002
    17
    Price, Ut
    So what is the total weight of a sbc or bbc? Thanks
  4. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Are you talking fully dressed (complete fuel/ignition system to oil pan, headers/manifolds, water pump, fan, power steering pump, alternator, etc), half dressed (block, heads, intake only), or bare block (no intake, heads, etc., etc.)?
  5. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I would guess fully dresses since the real question would be the weight gain from having a small block to going to a big block. Right now I have a 400 small block that I always understood to be one of the lightest small blocks due to the larger bore (less metal on block) but am not certain about this assumption. I have a good 454 on the stand in the garage and was wondering what the total weight gain would be. Right now with my setup and my new soft top, I weigh in right at 5400 pounds with the 39.5".
  6. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Small blocks are just under 500lbs. I had a bare block 350 and 400 in my garage at the same time and the 400 was heavier. Where it all came from I'm not sure but there is a difference.
  7. Supergas
    Supergas 1/2 ton status
    Oct 17, 2001
    161
    Texas Coast
    About 200 pounds difference....
  8. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    A BBC with Aluminum intake, water pump, and headers should be around the same weight as a stock SBC with cast iron manifolds etc.
