Does anyone know....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Pugsley, Aug 28, 2001.
  1. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    What the little resistor thing on the back of the oil pressure (OEM electric) gauge is called, and if they sell it seperately? I dropped my gauge this morning and broke the thing - I picked one up at the boneyard, but now my gauge is pegged at 60 psi (at idle), and I have no choke function [​IMG] The boneyard one has a yellow stripe on it, and the OEM was orange - is there a difference?
    If the shoe fits, get another one just like it
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  2. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,260
    72
    Humboldt/Pacifica, CA
    If it is a resistor then those colored bands tell the value of the resistor. There should be three colored bands (for a normal resistor). If you give those to me I'll tell you the value.
  3. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    it's only got one 1/4" stripe across it - no numbers or anything. I don't really know what it is - I just assumed it's a resistor, since it's ceramic.
  4. dyeager535
    26,978
    I've seen numerous of these as well. Best bet is to collect as many as you can, and keep swapping until your gauge reads what you think is correct, or what it was reading before. I believe the "resistors" must have been used to "tune" the gauges, or else there wouldn't have been any difference in them.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  5. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Thanks - I'll start harassing the other boneyards in the morning!
  6. Grim-Reaper
    7,385
    Atlanta
    One Stripe would indicate a Capacitor. should be a number on it for it's value. One stripe on one end could also be a Diode.
    It's not my damn planet monkey boy!
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    75 Jimmy, Dollar
    79 Chevy Blazer, Her's
    70 Chevy Burb
    Grim-Reaper
  7. dyeager535
    26,978
    These are definitely not diodes or capacitors, at least in the respect that I think of them. (no electrician here!)
    They are perfectly flat ceramic pieces, with colored "tape" stuck to the back of them. Not really a stripe, just some different colored tape. They are maybe 1/8" thick, about 1" long. Appear to be totally ceramic, except metal around the two post holes where it is held to the gauge.
    Anyone want to test resistance on a couple of them they have lying around?
    Dorian
  8. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I found the answer to my prayers this morning - an entirely different gauge assembly for $10. Works perfect, and reads within a few psi of the mechanical. Those little ceramic things must be tuned to each individual gauge.
  9. Emmettology 101
    May 9, 2000
    8,126
    FL
    Take the broken gauge to Radio Shack and see if they can test it or fix it for you.
    Mike
    <font color=green>"It's like a sore dick deal, You cant beat it!"</font color=green>
    <a target="_blank" href=http://www.geocities.com/emmettology101>www.geocities.com/emmettology101</a>
  10. dyeager535
    26,978
    Got a multimeter, and could you test resistance of the different ceramic pieces inthe name of science? : )
    Dorian
  11. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    The yellow one read 3.72 ohms, and another lavender/purple one read 4.14 ohms.
