Does Anyone Know .....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Neko H, Jun 2, 2000.
  1. Neko H
    Neko H Registered Member
    May 31, 2000
    21
    Texas
    Does anyone know if GM makes a tach that fits in the instrument pannel cluster that is small enough to fit where the clock usualy sits? I dont have a clock in mine so it is an empty spot and I would like to have a tach there. If so what it the GM Part number for the gauge and cables? And is this all I would need? Is it hard to install and set up.
    Or will I have to replace the large gas gauge with a small one there (in place of the clock location) and use the large tach? If so What are the part numbers for this?
    Neko H
    79 GMC Jimmy 4x4
    (If I'd only win the Lottery, it would be Cherry)
  2. smack
    smack 1/2 ton status
    Feb 24, 2000
    277
    Colorado
    hey Neko, that's what I wanted to do,
    From what I've found there's never been a GM tack that small for our applications. Only the big one where the fuel gauge goes for older pickups. I was hoping to buy a small fuel guage -- which is available -- and buy the GM tach and stick it in the fuel guage spot. Only problem is that tach is REAL expensive. Therefore, I've never done it. Summit Racing and LMC are good sources for guages.
    Jason
  3. Neko H
    May 31, 2000
    21
    Texas
    Sounds like a trip to the wrecking yards is in order then & hope I can find a working tach and a small fuel gauge.
    Do you know if the cableing for the gas gauge will work off of the large guage on the small gauge and will it reach?
    Neko H
    79 GMC Jimmy 4x4
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I heard it was a huge pain in the A$$ to swap out the giant gas gage for tach, but I might be wrong.
    YEEE HAWWW[​IMG]
  5. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    IF, and I mean IF you find a factory tach, you need the entire cluster including the wiring, etc. as the wiring printed circuit sheet is different than what you have now. At the same time, get the gas gauge, try to buy the whole cluster as a unit. The gas gauge and tach wiring is specific per wire circuit sheet.
    '79 - 406 w/IROC TPI - K5#5 - a <font color=orange>sickness[​IMG] <font color=blue>you never get enough of!! [​IMG]
  6. BillR
    BillR 1/2 ton status
    Mar 15, 2000
    164
    Flagstaff, AZ
    I think Autometer makes one that small. I've never seen a factory one that size.
    Blazin' in Flagstaff
  7. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    Summit has some small tach that might work.But why do you want a small tach its harder to see.I would get a 5" and either put it on the colunm or on the dash much eiser to see and keep track of the revs.Brady
  8. PattBlue
    PattBlue Registered Member
    May 3, 2000
    82
    N.W. Pennsylvania
    I 2nd what Brady said. I put a small/thin piece of metal on mine and slid it between the instrument panel cluster and the dashboard. Works good. I've also seen the column deal and that works.
