does anyone like there gov-lock?
Discussion in 'The Garage' started by 4trolls, Mar 6, 2005.
  1. 4trolls
    4trolls 1/2 ton status
    Nov 13, 2002
    190
    vancouver wa
    does anyone like there gov-lock? is there a way to rebuild it a little better? does it ever really lock up? mine is a 14bff and the gov-lock isnt working, I was going to weld it up but if the gov-lock can be made to lock then I'll just rebuild it
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I have a Gov-Lock in my 14 bolt. In the mud or on the street where the truck is on a level surface it works great. But if it leans a lot to one side it will only work half the time. When it locks in though it seems solid from one side to the other.
  3. sweetk30
    Nov 1, 2004
    25,552
    546
    horseheads , ny 14845
    i love it in my dd truck for traction and easy tire wear for street . but yes if hard core all the time full locker would be in it.
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    mine works, and its better than an open diff. id throw it out if i had something else besides an open, or weld it if it wasn't my DD.
  5. short sub
    short sub Registered Member
    Jan 17, 2005
    98
    Sealy Texas
    i had one in my blazer- key word is HAD. while it was bone stock i left a red light and heard a loud boom and i felt it through the floor, my rear diff. was officially open after that. After looking at the axle- i discovered a crack on top the 10b housing the gov lock literally exploded and broke the housing in the process. over the years i have seen quiet a few gov locks go wrong so i would try something else if possible
  6. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    My gov lok works fine when I'm on even ground where traction is nearly the same on both sides. It is probably worn out. I would definantly consider a brand new gov lok for my 14BFF if I was going to rebuild my rear end for some reason.
    Short sub,
    The gov lok in your 10B is weak like you mentioned, it's the same with a 12B also but they are much stouter in a 14BFF.
  7. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I've heard the 1 ton versions are pretty strong. I blew up my gov-lock in my 12 bolt this winter doing some high RPM wheel spin in snow. My diff is just open now. I'm switching in a 14 bolt this spring with a gov-lock. I really notice the difference now without the locker. When I spin, I spin in a straight line.... its not as fun.
  8. dyeager535
    26,982
    191
    Do you understand how they actually work?
    I've not heard of a 14FF gov-lock blowing up. Of all three common GM diff sizes, the 14FF is the only one that doesn't seem to have problems.
  9. RustBuket
    Feb 21, 2003
    1,618
    The gov-lock works by "sensing" difference of wheel speed between the two axles. When the difference is great enough some sort of ratchet or something locks up the axles. This is a problem because the inertia of the tires creates alot of stress on parts by shockloading. 1/2 ton diffs just aren't up to the task generally if you get any wheelspeed going on.
  10. 4trolls
    Nov 13, 2002
    190
    vancouver wa
    no ,I dont know how they actually work, could someone tell me?
  11. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    They don't seem to grenade, but when I took mine apart it was no longer functional. The governor mechanism which has these gears n teeth n whatnot seem to strip out rather easily. Once the governor no longer works neither does the gov-lock, leaving you with an open diff. Mine is now welded, no more problems :D
    __________________
    '77 K5, Warn M8000, 402/350/203, 44/14bff, 4"/36" Irok's
    http://www.krazyk5.com
    http://community.webshots.com/user/trcksr4me
    http://community.webshots.com/user/trcksr4me2
  12. dyeager535
    26,982
    191
  13. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    Is the governor lock what is in my 2001 Yukon XL 4WD? If so, it doesn't work well. The wife got it stuck today in my grass lawn.
  14. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    lol
    I killed one from a 1 ton 14 bolt..but that can be exspected if I was behind the wheel:dunno:
    :D
    mine went BOOM
    I had to drive home on the front shaft, in 2wd I could put it in gear and get out and watch my rear drivehaft spin:crazy:
  15. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I like mine... My daily driver (97 Z71 w/ 4" & 33's) has a gov in the rear, and I like well enough. Now, when I got the 14 & 60 for my K5, then yeah, no doubt a DL was going in the 14... I ended up getting a DL for the front too. But, for my DD, the gov gets it done.
  16. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    My 14bff Gov-Loc came to me with the teeth stripped off. From looking at the design I can see where some wheel speed b4 engagement could easily kill those tiny little parts. Excellent concept, flawed execution.
  17. dyeager535
    26,982
    191
    I guess I just hadn't heard of the 14FF problems.
    I can vouch for the 14SF being the same way...the small teeth just aren't a strong part, and never can be. Even a chip of metal running through those gears could very possibly strip a few teeth off, rendering it less than 100% effective.
    It is certainly an excellent idea, just too bad they couldn't beef up the operating parts of it better. I have never had the chance to look at a 14FF, I just assumed that since they *seemed* to hold up better, that the design (due to the carrier) was different and thus stronger. Well, stronger being relative apparently. :)
  18. mtnman
    mtnman Scrap metal fabricator Premium Member
    Sep 8, 2005
    2,087
    31
    On the farm , Missouri
    I've blown up 2 14blt gov locks - 1 sf 1 ff. Same technique, lots of tire spin + sudden traction = grenaded gov lock
  19. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Yeah, but i have also seen how you drive too :D :p: :wink1:
  20. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    are there any available clutch kits that allow the gov-lock to act more like a locker, or that make them more sensitive?
