Does anyone make 10 deg. shims........
Discussion in 'The Garage' started by FRIZZLEFRY, Apr 9, 2002.
  1. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    ........besides me.Im making some out of aluminum right now till I get my rear pinion angle figured out.The shims will be bolted to the spring pack.If 10 deg. works I will make some out of steel.If 10 deg. dont fix my vibe,Im plunkin down the cash for a CV rear shaft.
    The biggest shims I see are 6 deg. Is there a reson for that?
  2. tRustyK5
    Jul 23, 2000
    36,184
    1,391
    E-town baby!
    The bigger the shim the less of the center bolt going through the perch. I'd be concerned the center bolt would see too much stress with a 10 degree shim bolted up to the spring. As a temporary measure to get your pinion angle dialed in it would work I guess.
    Rene
  3. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Frizz,
    I've never heard of a 10* shim. I would think that past 6* the thing might want to spit out of place so bad that it might not be a good thing.
    Long term, I think a good CV shaft is the way to go.
    Marv
  4. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I only had to fool with my 12 bolt a little to get the angle right but this 14 bolt is kickin my a$$ /forums/images/icons/crazy.gif.Iv made 3 sets of shims to try and get rid of this vibe.I was setting up the mill to make the 10s and said "SCREW THIS".
    I just got off the phone with Jesse at High Angle and Im just gonna order CV drive shaft.Gonna go home tonight ,get the pinoin pointing straight at the t case,take a measurement,and order it tomorrow.It will be $$ well spent if I never have to fool with the freakin angle again /forums/images/icons/laugh.gif
    Thanks for the input guys /forums/images/icons/smile.gif
  5. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    does the pinion on the pumpkin have to point strait at the CV when putting one in? or can it point anywhere it wants??
    ARQ.
  6. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    w/ a CV shaft, it should point directly at the x-fer case. I left mine pointing a little lower cuz the axle will rotate up during acceleration.
    Marv
