Does Anyone Make......205 Questions
Discussion in 'The Garage' started by 84 K5 4x4, Feb 6, 2007.
  1. 84 K5 4x4
    84 K5 4x4 1/2 ton status
    Nov 14, 2006
    163
    Jasper Ga
    Does anyone make a flat style yoke that is 10 spline for the front output shaft on a 205?:confused:
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Not that i'm aware of. The 32 spline front conversion will net you the most options for yokes. The output shaft swap is easy.
  3. 84 K5 4x4
    Nov 14, 2006
    163
    Jasper Ga
    How easy is it to do? Do you have to do a complete teardown of the tcase?
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    All you need to do is remove all the bolts on the back cover plate and pull the shaft assembly out. I can't recall but i think the gear needs to be swapped over then reinstall. The only real issue is making sure that all the needle bearings don't fall out of the cover plate.
  5. 84 K5 4x4
    Nov 14, 2006
    163
    Jasper Ga
  6. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    bigger the splines count the bigger the shaft dia on the 205s. so you would only be making a weak link weaker.
  7. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Do you mind explaining what you mean. :confused:
  8. sweetk30
    Nov 1, 2004
    25,548
    543
    10 spline = weak
    30 spine = better
    32 spline = best
    so like i stated the bigger the spline count the better. so flat flange on 10 spline just be a weak link in the long run.
  9. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Well what you said here leads to believe that going to a larger spline count and larger diameter shaft makes it weak. I've re-read this about 6 times now and i get the same thinking everytime.
    I agree with he smaller spline count and diameter being a weak link. More than a weak link though is the inability to choose different yokes configurations.
  10. sweetk30
    Nov 1, 2004
    25,548
    543
    he asked ( Does anyone make a flat style yoke that is 10 spline for the front output shaft on a 205? )
    so i said ( bigger the splines count the bigger the shaft dia on the 205s.
    so you would only be making a weak link weaker. )
    so if you read his question then read my response. it will make sense.
    so if it dont make sense dont read it .
  11. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    You obviously have a problem with me and you and i both know why. I was only asking for an explanation of what you meant since it made no sense to me after reading it 6 times. I was not being a smart ass and trying to start any crap either. Oh well, whatever. :mad:
    You never even answered the guys question let alone made any sense in what you said. :crazy:
    This makes the most sense and would have been the appropiate answer the first time.
  12. 54inches
    54inches 1/2 ton status
    Feb 9, 2004
    1,535
    Houston, Texas
    Wow this is fun.
    Who all makes the conversion for the 32 splines?
    ORD,
  13. k30bb468
    k30bb468 1/2 ton status Premium Member
    Oct 2, 2004
    955
    NW Pennsylvania
    Ya need to get a FORD NP205 to get the parts for the 32 spline swap
  14. sweetk30
    Nov 1, 2004
    25,548
    543
    if i have a problem i try and do it threw pms. not in public to trash others posts. so if you dont like me or thinks i post add me to your ignore block section so you dont have to read my crap.
  15. 54inches
    Feb 9, 2004
    1,535
    Houston, Texas
    Are you sure? That sure does not sound right.:doah:
  16. Tominator II
    Tominator II 1/2 ton status
    Nov 5, 2005
    280
    South Park CO 80440
    When I put a new clutch in my 77 Jimmy last year I swapped out it's 205 with no sidemount bolt holes for an earlier 205 case that had side mount bolt holes but the earlier one had a U yoke instead of a flat output so I swapped the shafts and yokes from the transfer cases. It was not too hard, didnt even need any directions. I never had a problem with 10 spline outputs but the flat flange mount c/v joint for the front driveshaft is way better than the earlier one so that is why I did it. I called ORD and they told me a 10 spline flat flange did not exist . I have a 73 plow/tow truck with a 454/465/205 that I have hammered on hard, the 10 spline output for the front output yoke has never had a problem so I have to call BS on saying it is weak. It has outlasted 3 driveshafts!
  17. k30bb468
    Oct 2, 2004
    955
    NW Pennsylvania
  18. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    Yeah, he's sure--but it's OK 'cause you're not really putting Furd parts in a GM, they're really New Process parts.
    Jimbo
  19. 54inches
    Feb 9, 2004
    1,535
    Houston, Texas
    RIIIIIGHT, now I get what you are saying......kind of out the side of your mouth........I reread it and the way you worded it, it sounded like you were saying that I had to get rid om my "chevy" NP205 and get a "ford" in it's place.
    Which you don't HAVE to do.
    That's why I INITIALLY asked who made the conversion parts, not what FORD parts I needed.
    Thanks for your help, I think? JJ :)
    ORD/Advanced Adapters it is then.
    Thanks JIMBO!
    Once again, you are my hero!
  20. k2mslskier
    k2mslskier 1/2 ton status
    Feb 18, 2005
    1,524
    Tucson, AZ
    Boy that was interesting, two people have a disagreement that almost leads two more people to have a disagreement. Glad it all worked out in the end.
