Does anyone make a suspension drop for the front???
Discussion in 'The Garage' started by Supreme70, Feb 6, 2005.
  1. Supreme70
    Supreme70 1/2 ton status
    Jan 19, 2005
    501
    Detroit, Mi
    :confused: I was wondering if anyone makes a suspension drop for the front like the shackle flip for the rear. Also does anyone make longer front shackles. I want to run the a smaller lift spring and drop the mounting point to acheive a taller lift.
  2. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    here ya go.... :whistle: :shame: :rotfl:
    neither idea sounds good to me... i know there can be serious issues with longer front shackles.. caster/pinion angle, stability... ORD makes a "slightly" longer HD shackle. http://www.offroaddesign.com/catalog/hdshackles.htm their purpose is for reasons other than lift, mainly to keep the spring off the frame..
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    there is really nothing wrong with dropping the front suspension mounts an inch or two. If I ever get the tools together I will fab one up and start selling it. I've seen it done a few times by members here with great success. As of now, no, no one sells a kit.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Hanger kits are quite popular for Ford Superduties. Those that think this is a hack job should check those kits out sometime.
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yeah but you never see those kits used alone they always have like 20" springs under them :rolleyes:
  6. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    that thing would roll with a slight crosswind.
    :screwy: :yikes: :thinking: :rotfl:
  7. Afireinside
    Afireinside Registered Member
    Jan 22, 2005
    61
    Aurora Colorado
    Look at those d-shaft angles.:blush:
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That is not true either. Many people use them with stock springs to get 4" of lift with the stock ride.
  9. Supreme70
    Jan 19, 2005
    501
    Detroit, Mi
    so who sells the longer shackles.
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    hill4wd sells some. as does www.diy4x.com , Kert is a member here by the name of Cybrfire. As for using longer shackles, it requires the shimming of the front axle to get a good camber angle going. Otherwise your steering will be messed up. You also hurt your shackle angle, which means you hurt your flex. I think most of the people that just run a longer shackle, eventually switch.
  11. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Probably another Chaindrive design.:whistle:
  12. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Hill 4WD sells beefy longer shackles. I have them, I also made drop hangers for the front. There both great, now im thinking about taking the leaf springs out all together!!:D Theres some pics in my webshots.
  13. Supreme70
    Jan 19, 2005
    501
    Detroit, Mi
    Hey k5monsterchevy, How many inches was your drop on the very front hanger and how long is the rear front shackle???
    1987 1/2 short bed chevy
    If it's not broke I will break it some how LOL
  14. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I think there both 2" longer. Ill measure tomorrow.
  15. Supreme70
    Jan 19, 2005
    501
    Detroit, Mi
    Thanks, would love to be able to drop the mounting point and run a spring with less arch. Im thinking of running the shackle flip with 4 inch spring in the rear but I havent fig. out the front springs yet, I know I want to move the front axle forward the 1 inch and get longer greaseable shackles. Dropping the mounting point would be a plus for smaller springs. I am looking for smooth ride and good spring articultion. Im also looking to run the M.T. Baja claw 37x13.5x16 on the truck. Looking to kept the tires tucked up close to body for less body roll, and I dont like the body way above the tires. just my thought.
  16. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yep there 2" longer shackles, and the hangers are a little over 2" longer.
  17. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    133
    You can see the driveshafts in the picture, and those angles are INSANE!:blush:
